How much POwer????
Old Jul 10, 2002
RollOut's Avatar
RollOut is an unknown quantity at this point
How much POwer????
Ok if we all were to get the supercharger/turbo for our cars how much power would they provide us...............................
thx
Old Jul 10, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
OMG...another turbo question................................. ......j/k man. If there was a turbo or supercharger out for our cars, it would probably have to be a low-pressure affair, adding maybe 40-60 HP...even then u would need additional mods and nitrous to make any real power.
Old Jul 10, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
Quote
[hr]Originally posted by: Silver2k1Dood
OMG...another turbo question................................. ......j/k man. If there was a turbo or supercharger out for our cars, it would probably have to be a low-pressure affair, adding maybe 40-60 HP...even then u would need additional mods and nitrous to make any real power.[hr]
Silver: do you think one for our cars could reliably run more that 7 to 9 lbs of boost?
Old Jul 10, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
i talked to a couple of guys over here in 757 VA that own
performance shops, and they said the max psi without doing internal mods
would be 7-8 psi, and run mid 13 sec in the 1/4 mile, these are ppl
that have been werking on turbos for like 10-15 years
Old Jul 10, 2002
Quote
[hr]Originally posted by: FamilyMan
Quote
Silver: do you think one for our cars could reliably run more that 7 to 9 lbs of boost?[hr]
Yes, only if you lower the compression to a more turbo-friendly 8-8.5:1, upgrade the fuel injectors, ECU mapping, and upgrade the rods, gaskets, and head studs...sadly, there are no rods or piston upgrades that I know of.
I think with the current state of technology and our engine's bias towards economy and cleanliness, 9-10PSI would just about be the limit--w/o having to pour serious amounts of $$$ into it.
Old Jul 10, 2002
FamilyMan's Avatar
What do you think is possible without a lot of internal mods, while running a 40 shot? Do you think 7 lbs would be reliable for drag racing? What do you think an ET would be?
Old Jul 10, 2002
Quote
What do you think is possible without a lot of internal mods, while running a 40 shot? Do you think 7 lbs would be reliable for drag racing? What do you think an ET would be?[hr]
Aaaah jeez...you might be pushing it with a 40-shot and a 7-psi turbo...you gotta remember that we don't have a knock sensor so it would be tricky to manage that...I suppose if you got a piggy-back fuel computer it might be possible. I would go with a lower psi first--say, 5psi--but if you can run 7 psi and a 40-shot reliably then you're probably looking at mid to low 12's, assuming good traction and no driveline gremlins...you might need to upgrade the clutch to handle the boost reliably though.
Edit: I don't yet have any hard data on our engine's specs but it seems that the stock fuel injectors' duty cycle might be too stingy to run a turbo at 7psi...then there's the issue of the lack of a return fuel line...
Old Jul 10, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
you guys are funny...
instead of sittin here askin the same questions, why dont u start researching where to find a shop to build u a turbo, THEN, start worrying about how much boost to run. then on top of it, the last thing u should be worried about is ur ET's. guaranteed u wont get over 50hp with a turbo on our cars at less than 10 lbs of boost. and yes, you will need to do many upgrades to our fuel system, as well as cooling down our car with a bigger radiator. u might want to find out from FLUIDYNE when they will be releasing an aftermarket radiator for our cars. or start lookin into to using a aftermarket radiator from a different application and custom mounting it. no matter wut u do or find, its gonna be alot of custom work, meaning A LOT of money and A LOT of time! prepare yourselfs, because it may not be worth it for just 40 hp.
Old Jul 10, 2002
BLUENVY01: I have been researching boththe turbo and supercharger issues lately but it seems there are not that many shops--at least here in Dallas--who will even work on a turbo for our cars yet. Besides, it never hurts to brainstorm a little...I need all the brainstorming ideas I can get. I have never kept a car totally stock and this one won't be an exception, it'll just take more time, money, and research than I thought it would.
Old Jul 10, 2002
bhayes82's Avatar
bhayes82 is an unknown quantity at this point
i've heard the same thing re: maximum boost on stock parts. pretty much everyone in the business says 8 PSI is the limit, unless you want to spend big $$$ on manifolds, computers, piping, and other engine internals...
but even 8 PSI on our engines would put you at at least 160, possibly even up to 180 HP. i dunno about you, but that's enough power for me [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 10, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
Guys more than enough on turbos to sastify your needs on this site...Peace...-LOCKED-
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
