rotating tires fixed my alignment
Old Jul 9, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
i posted a few eeks ago about my steering wheel pulling to the right,,,even after 2g's in repairs
well today i went to honda to get an oil change,,and i asked about my problem.
when they were done, they guy told me that he cross-rotated my tires,,and it feels fine. i thoguht to myself, "what a bunch of BS". well to my surprise..on the drive home, the alignment was perfect. i was psyched.
so i was wondering...do neglecting to rotate tires cause such a drastic pull in steering?
Old Jul 9, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
THe problem was probably the fact that one of your tires was not balanced properly. I had the same problem with my car. The passenger front tire had a weight that fell off and the uneven tire wear had gotten to the point where it would pull the car a smidge to the right.
Old Jul 9, 2002
Strider's Avatar
Strider is an unknown quantity at this point
I'm just now having to start using the steering wheel to drive straight for a while... just thought I'd share w/ yall-
Old Jul 9, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Tire balance will not affect directional pull of the vehicle. But uneven wear will. Think of having one shoe on and one off. The difference in height, no matter how slight will make the car pull to that side. You probably make more turns to one side (rt or lt) than the other. That causes more wear on that so the tires are taller on the other side.
However, this would not be fixed by regular rotation of tires, but counter-rotation puts both tires from one side to the rear and both from the other to the front. If they are even up front you will not get the pull to one side.
Old Jul 9, 2002
solar's Avatar
solar is an unknown quantity at this point
Like Silver Devil said, "Balance will not effect tire "pull". When I was a mechanic I found that if you rotated the tires and the car quit pulling it could also be a bad tire on the front of the car. The tire may not look bad or have a vibration but the belts could have slipped. I'm not saying thats what your problem is but its a 50% possibility. Keep your eye on your rear tires now.
Old Jul 9, 2002
thanks for the input guys...ill have to shop for some tires soon/....for the time being though, is it safe to drive? (assuming that is the reason)
Old Jul 10, 2002
solar's Avatar
Quote
[hr]Originally posted by: StraightEdgeCivic
thanks for the input guys...ill have to shop for some tires soon/....for the time being though, is it safe to drive? (assuming that is the reason)[hr]
Yes its safe to drive, like I said I dought that your tires are bad but it is possible. If you notice a shimmy or vibration when you slow down coming from the rear end then you might have a bad tire. If the car feels fine though; I wouldn't worry.
civicowner123
Jul 24, 2015 10:02 PM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
technosilver
Nov 14, 2001 10:58 AM
