Does dropping the car create less aerodynamic drag?
Old Jun 10, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Does dropping the car create less aerodynamic drag? Hmm.. i was just thinking that if a car is lowered, there is less air coming below it so it would have an easier time rolling..
Old Jun 10, 2002
JKEEZO's Avatar
JKEEZO is an unknown quantity at this point
well... technically it does, but it wont really help you much in lets say the 1/4
but that is why racecars are always so low (because they go like 220)
Old Jun 10, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
the lower you go the more likely you will scrape something [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 10, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
i think it does a little but its mainly for taking turns
and handling alot better and if you have a CAI you get
colder air closer to the ground and your car looks alot hotter
slammed to the ground then high up in tthe air...
Team Turismo
Old Jun 10, 2002
17VtecE's Avatar
17VtecE is an unknown quantity at this point
"less air coming below it " that'll make the engine run hotter too
Old Jun 10, 2002
ak's Avatar
ak
Retired Mod
If i drop it 1.5" front 1.75" rear, will i need those chamber kits?
Old Jun 10, 2002
FLY's Avatar
FLY
FLY is an unknown quantity at this point
any drop and the camber will be off it is really up to you pretty much the rule of thumb with our cars is if its past 1.5 inches you will need the camber kits or you will be wasting money on tires.. i myself have a 1.5 drop all around the front looks fine it is off by like .5 degrees negative but the back could use a camber correction but its not bad enough that i have to drop everything to get it fixed so basically it is up to you with a 1.75 dorp i would highly recomend it or youll be chewing up your tires hope any of this helps and remember this is all my opinion.. some will say any drop and you need one......... so decide for yourself
Old Jun 10, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Just in case get em ak...Im not sayin ur gonna need them for sure...jus insurance.
Old Jun 10, 2002
ak's Avatar
ak
Retired Mod
What would be a decent price for the front/rear chamber kit?
Old Jun 10, 2002
FLY's Avatar
FLY
cant remember what the price on em are just pm Rob from torn active he will hook you up with the best deal
Old Jun 10, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: ak
If i drop it 1.5" front 1.75" rear, will i need those chamber kits?[hr]
naw, usually you need a camber kit once you hit 2 inchs or lower. you should be fine.
mikemc422
Aug 9, 2018 05:41 PM
leon1
Apr 28, 2015 07:32 PM
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
