attn: people with octane front bumper
Actually the bumper only mounts in four places. Two on each side and two under the hood.
I guess if you wanted to you could screw it to the ground to ensure it doesn't fall off.
you put the screws into the factory locations in the fenderwell, but not under the hood. if you put the 2 screws in the factory locations under the hood, they are very close to the edge of the lip thing. the body shop that put mine on went back a little further just to be safe, you just use self tapping screws and screw it in. that will help against cracking. and then, to be safe you can put double sided 3M sticky tape in the place where it goes in under the headlight, that will prevent it from popping back out. thats how my local body shop installed mine.
ibilalx
Jun 17, 2015 11:00 PM
SQCivic
Nov 8, 2001 05:56 PM
