What does a fly wheel do?
Old May 26, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
Just wondering...i want to buy a new one cuz im buying a bunch of new stuf for my car!
Old May 26, 2002
illusion's Avatar
illusion is an unknown quantity at this point
I think it's the wheel that connects the starter to the engine when you start, a solanoid pushes it into the engine, then disengages it once you let go of the key.
Old May 26, 2002
VNlilMAN's Avatar
The Standard One
it makes the shifts faster... like on a manual red lining, when your in 1st n switching to 2, your rpms might fall down to like 3, but with a flywheel it might fall to just 4, giving you more power. i'm not 100% sure about this so dont quote me, and the examples i give probably arent accurate but you get the idea...
Old May 26, 2002
kFanghe's Avatar
kFanghe is an unknown quantity at this point
A flywheel keeps the engine running at a consistant speed (i.e. from stalling and from running too irratically). The flywheel connected to the engine and is always engaged or turning with the engine. If you get a lighter wheel, your engine will rotate faster (quicker acceleration, etc.) but the caveat is that if the wheel is improperly lightened it will mess up your engine (not exactly sure as to how yet but it will). Plus, installing one is major $$$ (more than the actual wheel I think)
Old May 26, 2002
Mikes02Ex's Avatar
Mikes02Ex is an unknown quantity at this point
The flywheel is bolted to the crankshaft of your engine. Then the clutch is bolted to it. But if your car is auto it has a flexplate which is bolted the same way to the crank, but instead of the clutch, the torque converter is bolted to it. If you get a lighter one of either of these, it will decrease your reciprocating weight and your car will rev faster. I hope this clarifies things[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 26, 2002
thanks. does anyone know if the whole engine must be removed from the car to install the flywheel? cuz its connected to the tranny or something..?
Old May 26, 2002
anibal's Avatar
anibal is an unknown quantity at this point
Hey baller, you don't need a Flywheel...you car's tranny is automatic...a flywheel is used on manual transaxle engines...becuase it's connected to the clutch system...autos have a torque converter[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
and you don't have to remove the engine, but you have to remove the transaxle to reach the Flywheel....it's located between the engine and the transaxle
Old May 26, 2002
Jhonda's Avatar
Jhonda has a little shameless behaviour in the past
What the flywheel actualy does is give the clutch disk something to press against ingaging the clutch which in turn makes the gears turn, which makes the wheel turn.
Old May 26, 2002
anibal's Avatar
Actually is used for various things, including the things you said
<< connects the starter to the engine when you start, >>
<< A flywheel keeps the engine running at a consistant speed (i.e. from stalling and from running too irratically). The flywheel connected to the engine and is always engaged or turning with the engine. If you get a lighter wheel, your engine will rotate faster (quicker acceleration, etc.) >>
But a lightweight flywheel will make your car go slower when going up hill, for the same inertia reasons...less inertia
<< The flywheel is bolted to the crankshaft of your engine. Then the clutch is bolted to it. But if your car is auto it has a flexplate which is bolted the same way to the crank, but instead of the clutch, the torque converter is bolted to it. If you get a lighter one of either of these, it will decrease your reciprocating weight and your car will rev faster. I hope this clarifies things >>
<< give the clutch disk something to press against ingaging the clutch which in turn makes the gears turn, which makes the wheel turn. >>
Old May 27, 2002
thanks everyone.....im a newbie i thought i could use one in my auto......lol
Old May 27, 2002
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Alright, I have read this thread, and I can tell you that you guys are close, but not right on. I am actually a hummer mechanic, and six months away from being ASE certified on regular standard style cars. A flywheel IS connected to your crankshaft. Recall that 99% of cars on the road have four stroke engines. Four stroke cycle includes, the intake stroke (pistons moving downward with intake valves open creating a vacuum sucking in air and fuel), the compression stroke (both intake and exhaust valves closed, piston moving upward in the cylinder to compress the air and fuel mixture), the power stroke (the ignition of the air and fuel by the spark plug forcing the piston back downward), and the exhaust stroke (the piston moving back upward to push the burned mixture out of the exhaust port).
Now, that we have that clarified, basically a flywheel is connected to your crankshaft which is connected to your pistons through the piston arms. The flywheel is offset on the crankshaft so that it can keep it spinning throughout the fourstroke cycle. The power stroke is what starts the cycle, but it takes the flywheel to keep it turning throughout. Getting a lighter one would help performance for obvious reasons. But this is essentially the purpose of a flywheel.
Old May 27, 2002
RESIDENT ROTOR HEAD
Did this help you to understand flywheels at all?
Old May 27, 2002
FastProf's Avatar
FastProf is an unknown quantity at this point
All right answers, the flywheel is connected to the crank, but it acts to store kinetic energy as potential energy. This stored energy will keep the rpms running smoothly. This means sudden loads will not have an immediate effect on the engine. Whether you are running uphill or down the rpms will not rise or fall suddenly. A heaver flywheel will store more energy, but is harder to spin up to speed, a lighter flywheel will spin up more quickly, but you loose the smoothing function that it provides. If you race, a lighter flywheel will allow faster reving, but a daily commuter should stay stock.[IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
nirvanaguy
25
Oct 26, 2017 07:26 PM
SuperNova18
15
Mar 12, 2017 03:11 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
