Low temp thermostats?
Old 06-13-2019
D17VTECPOWER's Avatar
D17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the rough
I have 2 main questions on low temp thermostats that no one seems to have the answer to. Thanks in advance to anyone who has answers
1. What is the effect of lower temperature thermostats on the engine's performance? I have seen dyno tests that show that the colder the coolant is the more power the engine makes, but I also seen tests showing that engines make the most power when fully warmed up, so a low temp thermostat could be counterproductive.
2. How would a lower temp thermostat affect the engine's longevity? I have seen companies claim that their low temp thermostats help reduce wear, but I would think that the engine's longevity could be adversely affected by running cooler than it is designed to run.
Old 06-13-2019
Colin42's Avatar
Received 1,139 Likes on 953 Posts
Re: Low temp thermostats?
just run the oem one, you're never going to see any sort of benefit
Old 06-13-2019
So no increase in power from running cooler?
Old 06-13-2019
Colin42's Avatar
Not at a basically stock power level
Old 06-13-2019
Thank you. What would be the effect on the engine's longevity? Would the engine wear out faster running a little cooler than it is designed to?
Old 06-13-2019
Colin42's Avatar
You're worrying about a non-issue
hdtrc
02-15-2018 08:05 AM
spyglass
06-10-2013 06:08 PM
DEZZIE41
11-17-2012 10:24 AM
motayba
01-04-2011 01:07 PM
mr22508
11-26-2008 06:28 PM
Quick Reply: Low temp thermostats?
