now THATS some POWER!
Old May 14, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
copied from the internet:
COOL NHRA FACTS
* One dragster's 500-inch Hemi makes more horsepower then the first 8
rows at Daytona
* Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro
per second, the same rate of fuel consumption as a fully loaded 747 but
with 4 times the energy volume.
* The supercharger takes more power to drive then a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the
supercharger on overdrive, the fuel mixture is compressed into nearly-solid form
before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output
of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the
flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above
the stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After
1/2 way, the engine is dieseling from compression-plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting
of it's fuel flow.
* if spark momentarily fails early in the run, unburned nitro builds up
in those cylinders and then explodes with a force that can blow cylinder
heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the big
end of the track) that sometimes cam lobes are ground offset from
front to rear to re-phase the valve timing somewhere closer to synchronization
with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an
average of over 4G's. But in reaching 200 mph well before 1/2 track, launch
acceleration is closer to 8G's.
* Drivers shut off before the finish line, or even dual parachutes will
not stop the car.
* If all the equipment is paid off, the crew worked for free, and for
once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this
sentence.
Old May 14, 2002
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
thats some incredible ****
Old May 14, 2002
FURY's Avatar
FURY is an unknown quantity at this point
PFFT, NO MATCH FOR THIS!!!!!!!11
HORSEPOWER+++++++++++
Old May 14, 2002
hjteq's Avatar
hjteq is an unknown quantity at this point
I can't even imagine 8Gs Psychos [IMG]i/expressions/face-icon-small-puke.gif[/IMG]
I want it!!!
Old May 14, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
I just read about the new Lenliefer(forget the spelling) Corvette? Motortrend compared it to an F/A 18 hornet. 0-60 in 1.89 secs 0-100 in 4.87 secs? 0-150 in 10.4 secs. Those are just estimates. I could not remember the numbers. Some quick times for a street legal car. They were using Mickey Thompsons though. The street tires are close in the their times.
Old May 14, 2002
bhayes82's Avatar
bhayes82 is an unknown quantity at this point
wow... so can an F-16... AND it can fly!
...not to mention fire satellite-guided missles to destroy that silly "drag racer" and its redneck fans [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 14, 2002
JoeB16's Avatar
and the ability to go faster then sound. now THATS some top end!
Old May 14, 2002
trevor's Avatar
trevor is an unknown quantity at this point
<< * Dragsters reach over 300 miles per hour before you have read this sentence >>
thats some sheit....
some good facts.
Old May 14, 2002
Spider883's Avatar
9K Redline Owns U
thats some good stuff there. if u got anymore cool info like that post it.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
