Pics from MIA '13 and also My EM2 died...
Re: Pics from MIA '13 and also My EM2 died...
Well that sucked. Thanks to my parents I just spent $200 to find out I had a bit of dirt under my ground wire connection. (which I was going to clean today anyway, but my parents called the towing company before I had a chance) It would've cost me nothing and taken about 10 minutes with some baking soda and water.
Don't actuallly have time to test the ballasts until tomorrow, but hopefully I can figure this one out pretty easily. I still think it's odd that the ballast is completely silent. The light actually came on this morning for a second and then died out again, but it seemed to be only half as bright as it should be. The driver's side (which I usually have to turn on twice to ignite) is now working perfectly on the first try. Also I should mention that the headlight fuses are good and I do not have a relay harness for them.
And thanks anyway Aetoc. I would've found the problem had I spent a little more personal time with my car. Unfortunately with my busy schedule and doubtful parents, I couldn't get around to it.
Got any of these (or similar) installed?
Poor connection between the clamp and the bare wire of the cable is common. Especially if the copper wire ever had acid damage.
This is what I have.
The larger diameter is the ground, the smaller one is the stock terminal connection that had to be spliced into the clamp because my old terminal was very badly corroded.
Also I forgot to mention, even though the car starts now, it takes about 3 seconds to turnover when it used to only take 1 second to start. Annoying :P
lol, now my headlights are doing something really quite amusing.
When I hit the switch the first time, the passenger light comes on, but not the drivers side. When I flip them off and on again, the driver's side light comes on but not the passenger's side.
What the hell is going on here
That leaves your HID setup. (Made in China? Water damage?)
This sounds very much like why I went through 2 different HID setups on my Hog (aftermarket, and one was Hella IIRC).
Now I have an LED headlight and spotlights from J.W.Speaker Co..
http://www.jwspeaker.com/
I'm reasonably certain it will not be the fault of the car nor its wiring.
Looking at the model 90 light on there, does that fit existing HID shrouds? Looks really tempting and LEDs are much more simple so there's less to go wrong, haha.
This is the headlight I put in my bike
And the spotters
(just the bulbs, not the housings pictured here)
Yes, the basic LED lights are quite simple.
Something else to think about: The 2013 Accord Touring has some LED headlights you could look at.
One side of my old DDM kit went out after going to a high pressure car wash, water got inside the connector and shorted it. After inspecting the ballast, the inside was completely charred. I think i warned you a few moths ago right?
I went with the Morimotos, and actually had a ballast not stay ignited. It worked for a month or so. TRS is sending a new one out. It can happen with any manufacturer but catching fire is not cool at all!
Kenny the Ricer
I have eBay HID kits, nearly 2 years, haven't had a problem yet.
Went through a couple power washes in the bay, no problems.
Just gotta play with lady luck.
Finally a conclusive answer to all my startin' problems!!!
I really hate to point fingers, but Kenny... this is all your fault......
I think the dealers may have "accidentally" bumped the connection back into place and thought they fixed everything. WRONG. After not starting 6 times today, I dug in again and found the culprit was the ground wire between the engine block and the frame. The solder was busted and the wires free to move around inside. So I went mad with a propane torch and a bunch of solder and packed it full
Now it all starts up in under 1 second again!
The HIDs kinda work better now (the drivers side even better than before, lol) but the passenger still side cuts out. I'll swap ballast on Friday because I'll bet that is the problem.
I learned the hard way Kenny. You better check our grounds too before the same thing happens to you
Crimp, not solder. Or crimp first, THEN solder.
At least that explains some of the other weird sounding descriptions you have.
Who removed perfectly fine ground straps the factory had in there, and replaced them with crap?
Actually the stock ground from the same spot was almost entirely corroded through. You could almost break it with a pinch of the fingers.
All the other joints are really good on these, but the solder at this joint barely reached into the wiring. Yes, they were crimped before soldered.
Just a bad picture. It was definitely crimped. If you don't believe me, just ask kennykid, lol
Kenny the Ricer
They weren't exactly crimped.
I don't have a crimp tool for that size.
They were folded up on each other.
I made sure all connections were snug and tight.
Had it wrung up on a pole, and tugged on it with at least 10lbs of force.
Made sure they were sturdy before sending em off.
Not sure how you (or the dealer) broke the solder off.
Have you seen the metal eating s**t they put on the streets here?
Everything rusts here. EVERTYTHING. And that are above the grille tends to be problematic. I'm not saying that's the main cause, but that entire terminal was solid brown underneath. Also the bolt holding in the connection may have been too tight and twisted and torqued the wire till it hit breaking point.
Kenny the Ricer
Possibly, and the engine moves around in there, so it may have tugged on that wire too hard.
But it still doesn't explain your headlight problem
Ahhh, good point. With the wire slightly twisted, the vibration of the motor could've been tugging on it until it finely broke loose.
The headlight thing, LOL, I dunno what's up. Now they both come on at first but the passenger cuts out after 10 seconds. Like I said, I will tests the ballasts on Friday.
Well, I fixed my headlight by uhhhh.... jiggling some wires around and reconnecting a few things.
Both ballasts and bulbs are still good.
Now back to the other point of this thread...
Who else really likes that ES1? The K-swapped EM2 is also awesome, but that silver sedan is awesome.
Glad you got it fixed!! Probably will happen again if you all you had to is wiggle them.
ES1's/ES2's ROCK!! It was sweet looking. The EM2 was also. I prefer the look of the sedan over the coupe.
I like them both equally.
It's really strange, but recently I've found myself preferring the style of the 01-03 over the 04-05. Even though the 04 is more modern and aggressive, i like the front bumper and side panels of the earlier one. It looks more natural to handle modifications than the new bodies do.
Kenny the Ricer
I like the 01-03 as well...
The only thing that bugs me a lot, is the license plate holder.
I think I might buy a spare bumper, and shave it off, then paint it.
Yea, I agree. I thought about converting to an 03-05 front for the more aggresive look but I think the 01 with a lip would be enough so I'm going with that. After seeing that ES I think it will be best. The license plate thing is annoying. Never thought about shaving it.
Kenny the Ricer
I think it'll be some work.
It probably is molded on with the bumper.
Will prolly have to cut it out, put a metal screen behind it, and bondo the **** out of it.
Lotsa work involved, but I think it'd be worth it.
