HELP!! EVERYONE LOOK!
Old May 5, 2002
ProDigy's Avatar
GT-S BoY
ProDigy is an unknown quantity at this point
Has anyone gotten a PIN or NAIL stuck in their tire yet??? Okay this is my first time i've seen it. . i was checking my rear left tire tonight and i just saw a small flat bronze circle on the tire. I'm guessing its a nail that i ran over. . .question is. . does anyone know how much it is to repair, can i get it any where ie pep boys? Ughh. . do i have to get a new tire??Do i go back to my dealer and show them? HELP ME! [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 5, 2002
crazydragon's Avatar
crazydragon is an unknown quantity at this point
Take it to somewhere that sells tires and they should be able to patch it, don't know how much it cost though
Old May 5, 2002
FroggerDude's Avatar
FroggerDude is an unknown quantity at this point
if its a small nail u can fix it urself.. just buy one of those tire patching kits. like less than 20 bucks and u can fix a few holes with them. but if its big hole than go get a pro to repair it.
Old May 5, 2002
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
$15-$20 at any Tire Kingdom, or any tire shop, don't pay anymore than that
Old May 5, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
a nail should be rather easy to fix...i dunno how much it is cuz my mechanic friend did it for me..but it took like 5 minutes
Old May 5, 2002
ProDigy's Avatar
GT-S BoY
since im probably going to the tire shop to fix it. . . .do you think i should rotate my tires now??? Ask them to rotate it. .cuz its already 5200 miles. . i know its not a lot. .but what the hell. . .its good for the car. . and for the thing i can buy at the store. . .i dunno. . i might let a pro handle it. . .there goes my conversion kit for the clutch money!
Old May 5, 2002
eProdigy's Avatar
eProdigy is an unknown quantity at this point
rotate and change that oil
Old May 5, 2002
mohawkboom's Avatar
dude!!! its less than $20 to fix a damn flat bro lol...
Just fix the flat yourself...or take it to any local mechanic..
Old May 5, 2002
dups's Avatar
dups is an unknown quantity at this point
I picked up a nail a few months ago and I just called around asking people if they could plug the hole. Second place I called said they would do it for free. Otherwise its usually only like 5 bucks and takes just a few minutes.
Old May 5, 2002
ProDigy's Avatar
GT-S BoY
I would do it myself. . but theres no tools i have. . .so i might as well go to the pros. . . .thing is. .today is sunday and i dunno if anyone is open?? you think??? eheheh but thanks all for the help. . hopefully i can get it fixed and ask to check the other tires or maybe rotate them. . . thanks again.. .
Old May 5, 2002
aZnVoYCe's Avatar
Take the wheel and tire itself to a local tire shop (ie: Firestones, etc.). You don't need to bring your car with you. They will check if it is repairable or not, but I doubt that it won't be reparable. Ugh, however you spell it. And about the rotation. If you check your manual, you should rotate it every 10k miles under normal conditions. 5k for severe conditiions. I do myne every 10k. Good luck! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 5, 2002
2k1BlackBeautyOwner's Avatar
2k1BlackBeautyOwner is an unknown quantity at this point
You can buy the patch yourself which is very easy to use, or you can go to any garage and they'll probably charge you like $10.
Old May 5, 2002
phlipsidez's Avatar
phlipsidez is an unknown quantity at this point
Buy the patch kit man.... takes like 5 mimnutes to repair. Easy.
Old May 5, 2002
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
i ran over a big fat bolt couple months back. it hella sucked. i could feel the bolt every time the wheel turned. i got it pulled out at a gas station for like $6. but i had to balance my tires too becasue my car started to vibrate on the freeway.
Old May 5, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
take it to tire shop....but in any case, you're going to have to buy new tire down the road anyways
Old May 5, 2002
smpcivic's Avatar
smpcivic is an unknown quantity at this point
I got mine patched for $5 at a gas station....took like 2 mins
Old May 5, 2002
Mbow's Avatar
Yep, had a few nails and screws in my time. Sometimes the object is in the rubber so tightly that the tire won't even leak. Although, you never know when it will pop out so it's best to fix it. I have a kit from Wal-Mart that included a tool to rough up the surface of the hole, the screwdriver thing to put the plug in, and several plugs and glue. You can buy a kit for like 4 bucks and do it yourself. It's very easy to do and will save you like 15-20 bucks. Just don't buy a cheap kit from pepboys or something because the plugs suck and the instrument for inserting the plug doesn't work very well. Plus, you are going to have this happen several times over the years so the saving will really ad up. I actually did a demonstration speech in a college class showing how to plug a tire.
Old May 5, 2002
PnOiCiViC's Avatar
PnOiCiViC is an unknown quantity at this point
yea..i got a fat screw stuck in my tire..I got it repaired for cheap at firestone[IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old May 5, 2002
Crash2002's Avatar
Crash2002 is an unknown quantity at this point
i took mine to the tire shop, it cost me 8 bucks
Old May 5, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
yeah i had the same problem. i took it to a small tire place and they fixed for $5. they told me i had 2 nails in my tire, i had only seen one
Old May 5, 2002
Hatchcivic's Avatar
Hatchcivic is an unknown quantity at this point
The tire shop by my house does it for $10 bucks, should be easy for them and take no more than 20 minutes to take out and fix
Old May 5, 2002
bambuski's Avatar
bambuski is an unknown quantity at this point
I usually do it myself, if not, a tire place will do it usually for 5-10 bucks.
Old May 5, 2002
Desi's Avatar
Desi is an unknown quantity at this point
- on my tires was going flat frequently and so i took it to sears to patch it up and they did it for 15 bucks.
Old May 5, 2002
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
Go to Les Schwab Tire Center. They will fix flats for free even if you did not buy tires from them, they have great service as well.
Old May 5, 2002
aferenz's Avatar
aferenz is an unknown quantity at this point
If your riding on stock tires take to firestone 20$, but you will rotate your tires for free.
Old May 6, 2002
Gdub's Avatar
Gdub is an unknown quantity at this point
it only cost 8.00 at walmart or pep boys.....all they do is plug it
