Spoiler removal!
Old Apr 15, 2002
Nitek's Avatar
Nitek is an unknown quantity at this point
Spoiler removal!
How much do you guys think it will cost to fill in 4 holes from an aftermarket spoiler?
Will they use bondo to fill the holes and panit it? has anyone done this before?
Old Apr 15, 2002
GeNoZiDe's Avatar
GeNoZiDe is an unknown quantity at this point
you have to buy a new trunk piece
thats like 150 - 200 canadian used i think
my friend owns a body shop
i ve asked him bout it
Old Apr 15, 2002
Sampsonite's Avatar
Sampsonite is an unknown quantity at this point
if they can fill it, it is hella cheap...i got an estimate on my car...they didn't tell me it was only to fill...it was like half of what it was to replace my rocker...it is hella cheap...if i were you though...i wouldn't settle for fill, you can probably find a decent price for a trunk lid, painted....peace
Old Apr 15, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
if u lived here in plano i could do it for around 100 bucks
no shop will fix it u will have to get the lid replaced and painted its prolly gonna run u around 440-540 dollars.
the lid is 240 USD at http://www.hondaautomotiveparts.com/
Paint materials are another 100-150 depending on color of your car.
and another 100-150 labor.
if u had a regular shop fix it the labor would cost more than the new lid.
as far as the process you have to weld the holes shut part way and fill the rest with plastic filler..sand down and prime/paint..because plastic filler (bondo) will not plug up a hole it needs a full surface to bond to.
Old Apr 15, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
d@mn!!! this mean if i replace the spoiler i have now im screwed? i wanted the holes filled, not buy a whole new d@mn trunk lid!!
PeArLhOnDa
Old Apr 15, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
i want to take mine off to but i dont want to buy a whole new trunk lid either
Old Apr 16, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
You guys are wrong!!!!!!!!!!!! I just a week ago filled 6 holes in a bmw 325i deck lid!! I used a small peice of metal as a backing on the top side and welded from inner jamb! Then i just ground both sides {the inner where i welded and the scrap metal backing] flat with 24 and 50 grit roloc discs from 3m! Then i sanded the metal with 80 grit sand paper, then lightly skimmed the metal with metal glaze {bondo} and sanded till smooth level straight and flat! primer and paint! I would tell you how to paint but then you wouldnt bring your car for me to fix! Just wanted to let ya'll know that your wrong! Dakota
GotSiR
Mar 8, 2017 05:33 PM
herbiej
22
Aug 23, 2015 01:02 PM
henrytn
Aug 11, 2015 10:01 PM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
