Wheel terms and perfect wheel size?
Old Apr 1, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey guys, I'm gonna buy rims soon and I decided to buy 16 x 7.0 Rota Sub-zeros.
I found them on Modacar, for 840.00 with some Kumho tires.
Anyone know of a place with a better price? Or better yet, does anyone know of a place where I can choose different tires?
I really wanted Nitto 555R's or some Toyo T-1's.
But anyways, if I do buy some tires I'd like to know what all the terms mean. I've searched, but I couldn't find what the terms mean.
So can someone explain to me what those numbers on the side mean. I would really appreciate it. Thanks.
Old Apr 1, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
What kind of Kumho's are you talking about. I have the Ecsta Supra 712's and they have plenty of traction.
My tires are 215/45ZR17
215= width of tire in centimeters(edit: make that millimeters)
45= distance from inside edge of tire(outside edge of rim) to outside edge of tire
Z= speed rating(Z rated tires are the only one that have the letter there)
R17= this of course is wheel diameter.
Old Apr 1, 2002
FurBall's Avatar
FurBall is an unknown quantity at this point
The default tire size for the LX and DX is 185/70/14 and the default size for the EX/Si is 185/65/15.
Use the online tire calculator to see how messed up your speedometer will be after changing tire sizes....Here
I could never really imagine the first number, the overall tire size in inches, nor the 2nd number [IMG]i/expressions/face-icon-small-smile.gif[/IMG] The higher the first number, also makes the tire fatter. 205, 215, etc.... The lower the middle number, the thinner (lower-profile) the tire.
The term "plus sizing" refers to shrinking the rubber (getting a lower aspect ratio, the middle number), and increasing the amount of rim (increasing the 3rd number), to maintain an overall wheel height of stock. (To maintain a sane speedometer.)
If you care about driving normal speeds over speed bumps and stuff, and have heard of the horrors of people with 17's or 18's (with or without lowering) having to go over speedbumps at an angle or potholes bending rims, you may have thought that you should just go with 15s, or 16s, but get thinner rubber. In doing so, you really put your speedo out of whack.... Going 68km/h might end up going 60km/h, or whatever....
"Ideal" sizes, based on tire calc, besides stock, (to maintain a good speedometer), is: 195/55/R16, 205/45/R17, or 215/45/R17.
I dunno why alot of the 2k1civic.com members choose xxx/40/R17. It throws their speedometer off by as much as 5%.... I guess they prefer the look of the lower profiler tire, and are willing to sacrifice looks for error.
Me? I drive on stock 185/65/R15 tires [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 1, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
""Me? I drive on stock 185/65/R15 tires ""
me 2
Old Apr 1, 2002
Grifter's Avatar
Grifter is an unknown quantity at this point
I'm lookin at some 205/50/17.. mad expensive... smooth I've heard.. and unless you have a ground effect kit.... I think 17 with low profile tires look silly dropped inside such a big wheel well
Old Apr 1, 2002
2002DX's Avatar
2002DX is an unknown quantity at this point
Hwoody77, if you want a good price search on ebay. Search for nitto tires or toyo tires and you should get plenty to choose from. I got my 17" konig vertict knockoffs and 205-40-17 tires for 760 with shipping included. Usually the good ZR tires for a set of four will run you about 300 to 450. Better than paying 150+ for one tire.
Old Apr 1, 2002
fraga's Avatar
Wicked Moderatuh
You could also try Discount Tires.
Old Apr 4, 2002
Mbow's Avatar
Which model are those the "ideal" sizes for in your opinion. I found that a 205/50/16 only throws the speedometer off by 1.6%. Pretty good in my opinion. That is for the ex model.
Old Apr 4, 2002
eskimo's Avatar
eskimo is an unknown quantity at this point
im confused.. how do u fix your speedometer to correct for speed? i want the konig imagines and im confused it doesnt list the size or something besides 17x7 40OS or something
Old Apr 4, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
The 2nd # is actually a percentage not an absolute amount. For example, a 205/40/17 tire has a sidewall height of 40% * 205mm = 82mm. A 235/35/17 tire has a sidewall height of 35% * 235mm = 82.25mm.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Honzy
Jun 25, 2015 06:28 PM
artychris
Dec 14, 2001 08:02 AM
VNlilMAN
Dec 6, 2001 01:25 AM
