question for the guys running a k24/k20 frank
Old Sep 10, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
ok 1st of all what timing chain are you using? k24 or k20? 2nd of all if any of you are running a high compression domed piston what valves are you using? is there any interference? thats all for now
Old Sep 10, 2007
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
Re: question for the guys running a k24/k20 frank
Im using the K24 Timing Chain since the block is from a k24.
High compression pistons I used 12.5:1 and used Supertech STD Black Nitrate coated valves so the c/r never jumped.
Old Sep 10, 2007
mugenman's Avatar
what rods did you use? and was anything done to the crank?
Old Sep 12, 2007
RAZRBLD's Avatar
TEIN MAN
Import Builders K24 I BEAM rods.. But you can use FI rods on a N/A Setup.. Rods are Rods. I had the crank micropolished. Thats all.
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
Grazzhopper
Nov 11, 2001 08:06 AM
papi2001civic
Nov 3, 2001 12:09 PM
wsking77
Aug 29, 2001 05:34 PM
