turbo tuning help.....
Ok I just got done installing everything including the management system. The management system is the XFC PCS from Dezod. After I had installed it my speedometer quit working, as well as the rpm gauge. Also my turbo is supposed to kick in at 3500rpm, and when my car reaches 3000 is tries to studder out or at least it sounds like it. so mycars not letting me go into boost. I was just wondering if anyones has ever had this problem and what it turned out to be? or sgguestions that it could be.please help if you can. thanks.
7thgen Power Maker
Re: turbo tuning help.....
Do not drive the car, because it sounds like it is running lean and causing it to shut down.
Check to make sure your tach stil works with the stock ECU and XFC unplugged. If it does, then the wiring is faulty or damaged and PCS needs to be notified immediately. If the tach and such still do not work with the XFC unplugged, then it is a problem with your car, and you need to address it.
7thgen Power Maker
A long winded 7th genr
I just want to say one thing, I think that this is really great. One car enthuiast helping out another seriously. Good work guys. It's good to see that people still help eachother out rather then just being dissentive.
word to that. but you also have to consider the fact that this post wasn't like "yo how do I remove my speed governor for max speedz."
Curious to see the outcome here - Paul knows why
. By the by, my 1st travel settlement should be in by Friday next week so we can complete the sale!
. By the by, my 1st travel settlement should be in by Friday next week so we can complete the sale! Thread
NaturalSelectio
Sep 6, 2015 06:59 PM
