help on HID installation
Old Nov 19, 2006
foureyeman's Avatar
foureyeman is an unknown quantity at this point
I just bougth a H4 HID kits and the lights didn't work , When I put that into the corolla 98 with the same kits, it works nicely.
My car is 2004 Acura EL 1.7 ,what can I do or need actually for installing HID.. relay, fuse... ?
Can anyone help me with this and sent me a good instruction because I am so new about that and stupid.. haaa.. thx..
This is the information of my ballast ...
input voltage :9-16V
Normal voltage :12V
Max input current:10A
Rated current:3.5A
Output wattage:35W
Starting voltage:23kV
THanks for help
sent me email if have a fully detail of instruction. foureyeman@hotmail.com
Old Nov 19, 2006
are you using an upgrade wire harness with relays? stock harness does not support hid. maybe your kit is broken
Old Nov 19, 2006
foureyeman's Avatar
i did use the relay kit and it still didn't work..
however, if i put the whole set into my friend's car (corolla) , it works.
Old Nov 19, 2006
foureyeman's Avatar
I have the relay kit from my old HID set. but it still didn't work when i connect the relay kit to my new HID kit.
however one thing i found out is that... the Max current input for my new HID ballast is 10A.. my old set is 20A. that's the only difference between my two kits.. the old kit worked on my car.
so can i say that my car is putting too much current to my new kit so that it didn't work.. coz i found out the fuse for the car's headlight is 15A.
Old Nov 19, 2006
gstyle's Avatar
gstyle is an unknown quantity at this point
Does it work if you turn on your High Beams? There is a slight configuration difference between a civic & an EL in reference to plug & play. Depending on your answer to the first question, I can try and point you in the right direction.
Old Nov 20, 2006
foureyeman's Avatar
well.. the high beam works.. however my H4 Hi/Lo kit is one of those that comes with 2 bulbs (one hid bulb and beside is the high beam halogen bulb)..
when i plug all in.. only the halogen high beam worked... the HID never light up..
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
