Jump starting car bad for Comp. and battery?
Old Sep 21, 2006
chicohonda02's Avatar
Since 2002 Baby!
i was told today that jump starting your car when dead, is bad for the on board computer and the rest of your car. is that true?
anybody?
Last edited by chicohonda02; Sep 21, 2006 at 08:55 PM. Reason: Automerged Doublepost
Old Sep 21, 2006
Maverick_1337's Avatar
Maverick_1337 will become famous soon enoughMaverick_1337 will become famous soon enough
i heard that too on my moms accord
Old Sep 21, 2006
tuner04civic's Avatar
spell check pwns you
well i know when i jumped my sisters car with my moms, the radar, which was a voice cobra one, went crazy and talks all distorted after that. but havent had any ecu problems or anything yet.
Old Sep 22, 2006
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
nah ive had to jump my car like 5 times over a 5 yr period and no problems at all. Stock battery and alternator is running strong still.
Old Sep 22, 2006
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
NO...it's not bad for your car as long as you are doing it properly. Most people connect positive to positive and negative to negative...which is wrong.
See here for the proper procedure of jump starting your car:
http://www.carbuyingtips.com/jumpstart.htm
basically:
DEAD CAR....................................GOOD CAR
positive terminal--------------------positive terminal
ground-------------------------------negative terminal
That's the proper way to setup your jumper cables. If you do it incorrectly you can potentially zap either or both your batteries as well as electrical components.
Old Sep 22, 2006
coupe2003's Avatar
coupe2003 is a jewel in the roughcoupe2003 is a jewel in the roughcoupe2003 is a jewel in the roughcoupe2003 is a jewel in the rough
It is true on some vehicles, though i don't know if it's the case with an EM2. Jumping a vehicle off can cause a power "spike" to the engine ECU. To avoid this, simply apply a load or two to the vehicle once the jump leads are connected, but before you turn the key. E.G., switch on lights, wipers, heated screen etc. It might not apply to the EM2, but it won't hurt to get into the good habit for the future.
I have to do it with the Renault trucks i work on, every time i do a jump start.
Old Sep 22, 2006
Since 2002 Baby!
MECHANCIC WHO SAID THIS WAS WORKING ON MOTHER INLAWS DODGE CARAVAN. SO SHE CAME HOME AND WAS YELLING AT ME ABOUT HOW BAD IT WAS TO JUMP CARS? wHAT THE HELL R U SUPPOSE TO DO, BUY BATTERY EVERYTIME YOUR CAR DIES? WTF
Old Sep 22, 2006
coupe2003's Avatar
If you're worried about this potential "spiking" problem, just add a "load" to the electrical system before you physically start the vehicle...as stated, switch on something (or things, plural) that draw(s) a decent current before you crank the car over.
You can do a battery test to see if your battery is still within manufacturers tolerances. If it is, you'll be fine and the battery will just need charging up (either by some fairly long driving/use, or actually attach a battery charging device to the battery over night).
Old Sep 26, 2006
Since 2002 Baby!
all right then.
Old Sep 26, 2006
all youre doing is using someone elses battery to start your car. how would that cause a problem.
Old Sep 27, 2006
coupe2003's Avatar
I did say i don't know if it applies to the EM2... but the 24 volt trucks i work on have incredibly complex electrical systems and you DO have to be careful how you jump start them. I didn't say you had to do it on your Civ.
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
