what type of gas do u guys use?
Old Mar 12, 2002
fourkilos's Avatar
fourkilos is an unknown quantity at this point
i spoke to two different dealers at two different place and they both tell me that i'm only supposed to use 87 oct. WHY?? is this true??
Old Mar 12, 2002
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
ummm....shiet...i know i use the middle one, i guess premium..but i dunno what octane it is.....my dealer said the same thing(to use lower octane)..i tried that and it suked!..so i went to premium and it is ok. I havent tried super tho. They tell you to use lower octane because of that ULEV..Ultra low emissions vehicle...My dealer said it doesnt need a high octane.
Old Mar 12, 2002
jonavin's Avatar
jonavin is an unknown quantity at this point
Because youll just waste money if you use anythign else. You're not going to get and more power or better mileage with higher octane gas. In fact, in my test (albeit unscientific) my mileage was WORST with 94 octane gas.
Don't bother using anything except 87 unless you add a supercharger or turbo. It might be more important which brand of gas you use as opposed to octane. e.g. Sunoco has the lowest sulfer content where I live.
Old Mar 12, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
<< ummm....shiet...i know i use the middle one, i guess premium..but i dunno what octane it is.....my dealer said the same thing(to use lower octane)..i tried that and it suked!..so i went to premium and it is ok. I havent tried super tho. They tell you to use lower octane because of that ULEV..Ultra low emissions vehicle...My dealer said it doesnt need a high octane. >>
that should be 89 octane... i use 92 octane and it's fine.
Old Mar 12, 2002
Wanger's Avatar
<< Because youll just waste money if you use anythign else. You're not going to get and more power or better mileage with higher octane gas. In fact, in my test (albeit unscientific) my mileage was WORST with 94 octane gas.
your wrong, you get what you pay for... if you got the extra money, use a higher octane, it burns cleaner and it'll be better for you fuel pump in the long run.
Old Mar 12, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
higher octaine makes it HARDER to burn the gasoline. This is why its needed in high performance, high compression, turbo and nitrous engines. read: to resist detonation.
If your car isnt designed to run high octaine fuel and/or if you dont have any performance mods that would require the use of it (ie forced induction or nitrous) its not only a waste of money, it will make LESS Hp with your economy minded powerplant. the end. close this thread.
Old Mar 12, 2002
RevHigh's Avatar
RevHigh is an unknown quantity at this point
Usually I just use 87 octane, though every now and then I splurge and go for Premium. I really haven't noticed any performance difference between either, but I'm sure that you always get what you pay for.....though it may not always be big
Old Mar 12, 2002
jonavin's Avatar
Higher octane doesn't make the fuel any cleaner. It's true that most gas companies put more detergents in higher grades (or at least they make this claim), but there government regulated minimums even in regular gas. As stated earlier, it may be more important which brand of gas you use. Some will have more crud than others.
You only get what you paid for, if you need it in the first place. If you ever manage to squeeze a turbo in there... then by all means, use premium.
Old Mar 12, 2002
sailorboy's Avatar
sailorboy is an unknown quantity at this point
If higher octane gas is just an option.........don't use it. That simple.
Old Mar 12, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
the liquid kind of course.
Old Mar 12, 2002
marker126's Avatar
marker126 is an unknown quantity at this point
I always go with 87 octane. I've heard to stay away from the really cheap gas stations, as the gas isn't as good from them. Ya'll have any opinions?
Old Mar 13, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
87 for me =)
Old Mar 13, 2002
GabberHead's Avatar
GabberHead is an unknown quantity at this point
Yup, what JoeB16 said, he da man.
Edit- oh yea... free post free post [IMG]i/expressions/moon.gif[/IMG]
Old Mar 13, 2002
RiceBuRNeR's Avatar
Turbo Member
I know that it is BS but my dealership tried to tell me that using supreme gas is what blew up my engine....and because I had an empty can of nitroboost aditive in my trunk they blamed it on that too (BTW nitro boost does really work I consistantly ran allmost 2 10ths fast when I had some in my gas tank)
Old Mar 13, 2002
robbclark1's Avatar
Retired suspension supermod.
Use 87 like the manual says. The engine wasn't designed for higher octane and don't switch octanes so much. it isn't great on the engine.
Old Mar 13, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
cheapest crap avail...
Old Mar 13, 2002
Mbow's Avatar
I stick with 87. I pretty much always fill up at the same place though.
Old Mar 13, 2002
2cute's Avatar
2cute is an unknown quantity at this point
The car was designed for 87 octane adding things like the octane boost and the fuel cleaners really doesn't do much good since these cars are designed for 87 octane. If you are concerned about the fuel leaving deposits run the 87 octane and then once every month or two run one full tank of the 91 octane since it burns hotter it will clean out all of the deposits.
Old Mar 13, 2002
01BlackEM2's Avatar
01BlackEM2 is an unknown quantity at this point
Hmm... I thought higher octane really only made a difference for higher compression
Also... the cheap gas stations like Thrifty, AM PM, Arco, UltraMar and other "cheap" gas stations are BAD. So it's better to stay away from them.
Old Mar 28, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
so if u were using 93 rite now.. is it ok to just mix in regular? theres no problem with that right? mixxing two different grades of fuel?
Old Mar 28, 2002
fraga's Avatar
Wicked Moderatuh
I've always stuck with good old Regular 87 octane. I just check to see if that one local State sticker is on the pump. If it's not there, I won't put in gas there.
Old Mar 28, 2002
the1sthotboy's Avatar
the1sthotboy is an unknown quantity at this point
i think there's no damn difference in any grade of gas other that diesel j/k, but I use 87....& occasionally when I get PAID ..goto 89....& (yes the NOS additive does work) you sure do get what u pay for but when it comes to $1.36/ gallon (HOUSTON) fu&lt;k that just stick with the cheapest anywayz since there is no performance difference..[IMG]C:\My Documents\The Pictures\painted.jpg[/IMG]
Old Mar 28, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
the cheapest which really isn't that cheap anymore
it's like $1.30 something for 87 octane
Old Mar 28, 2002
avenger's Avatar
avenger is an unknown quantity at this point
hahaha 1.30 for 87 [IMG]i/expressions/laugh2.gif[/IMG]
can you ship me some gasoline for that price??
Old Mar 28, 2002
Snowman's Avatar
Snowman is an unknown quantity at this point
Good old 87 at like $1.57 or somethin.
Old Mar 28, 2002
OUTLAW's Avatar
OUTLAW is an unknown quantity at this point
Just looked in my little Civic owners manual and used the 87 octane. But I use what ever is cheap it isnt like I am racing on Sundays.
Old Mar 29, 2002
Voiceofid's Avatar
End Bringer
depends on my mood, if i feel like a rich bastard, i'll get 92, if it's like eh... what the hell.. 89, and if i am just cheap and no cash and don't give a damn - 87
Old Mar 29, 2002
Jandree22's Avatar
Jandree22 is an unknown quantity at this point
<< depends on my mood, if i feel like a rich bastard, i'll get 92, if it's like eh... what the hell.. 89, and if i am just cheap and no cash and don't give a damn - 87 >>
nice approach to the octane debate [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 29, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
i use 87 sometimes then like every 3rd time i use premium i dont know if this is good for the car or not but yea thats what i use..
Old Mar 29, 2002
2k1BlackBeautyOwner's Avatar
2k1BlackBeautyOwner is an unknown quantity at this point
was told to use only regular unleaded.
