Pro's & Con's Of AfterMarket Sunroof/Moonroof
Old Feb 26, 2002
LilCivicKidd's Avatar
LilCivicKidd is an unknown quantity at this point
I'm really thinking about having one installed since A/C didn't come with my car. But I want to know some good and bad's about them! Please help!
Old Feb 26, 2002
Civic2k2RacerX's Avatar
Civic2k2RacerX is an unknown quantity at this point
they can break when they get older and they cost a lot to install..... but damn i love my ex's moonroof
Old Feb 26, 2002
VTEC808's Avatar
VTEC808 is an unknown quantity at this point
The only actual bad thing about it is if the shop doesn't get it 100% sealed. Then as you can guess, water will be dripping from the sunroof.
Old Feb 26, 2002
Dynamic's Avatar
Dynamic is an unknown quantity at this point
I'm not sure about the 2k1 civic, but i know installing an aftermarket sunroof in a car like the camaro or firebird requires cutting the roof support, thus killing your safety in a roll-over. Some cars which include sunroofs have extra strength measures incorperated into the roof area to compensate for the sunroof, but like i said, i dont know if the civic is like that. Also, ive always heard that aftermarket sunroofs have a tendency to leak ALOT... ALOT more than stock ones.
Hope this helps
-Dynamic
Old Feb 26, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
so expensive..
shoulda just coughed up the money for an ex...but i guess that still would be a lot more...
shoulda coughed up the money for the A/C group...[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 26, 2002
Dynamic's Avatar
i would personally just spend a little extra money and get A/C installed. Air outside is always hot anyway [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 26, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
well i think you know the pro's: more air, looks cool, you can let the sun/moon in, cheaper than AC and can be very effective if going fast enough, sometimes cheaper than getting the more expensive car with a sun/moon roof
cons: it can be noisy if you don't have a wind deflector, it can be whistle if its not sealed correctly, IT CAN LEAK <---i think that is the number 1 con, structural integrity (good think the civic isn't a supra!), leaks that rust the roof
personally the con's aren't really that bad to me and now-a-days i don't hear people complaining about them. if you go to a quality place with a warranty, you'll be str8.
Old Feb 26, 2002
im guessing there are no pro's....lol
Old Feb 26, 2002
MyOtherRideIsBritney's Avatar
MyOtherRideIsBritney is an unknown quantity at this point
Um, if you're getting a sunroof to compensate for a lack of A/C, that seems pretty weird...
Just roll down the windows...
And about sunroofs...they do add weight, because more roof support is often added by manufacturers when the roof is cut. This is why the 5th gen. Civic hatchback is most desirable in the CX, DX, or VX forms, because they weigh less than the moonroof equipped Si.
Just my 2 cents....
Old Feb 26, 2002
i withdraw my last post..thanks SuziQ
Old Feb 26, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Yeap I think its pretty mucn unanimous that aftermarket sunroofs tend to and will most likely leak eventually. Question is....how long? and will you keep the car that long?
Old Feb 26, 2002
only time will tell
Old Feb 26, 2002
blah's Avatar
blah is an unknown quantity at this point
I had an aftermarket moonroof installed on my lx sedan. It wasnt cheap. $800 installed with 2 yr warranty through honda. No problems at all. Doesnt leak, no wind noise etc. Overall im impressed with the work and happy with the result.
mike
Old Feb 26, 2002
2 year warranty seems pretty short. Is there longer warrarties to chose from?
Old Feb 26, 2002
blah's Avatar
2 yrs was all they would give me. You'll be hard pressed to find a warranty like better than that. Our whole car is only warrantied for 3 yrs.
mike
Old Feb 26, 2002
SWEETRIDE's Avatar
SWEETRIDE is an unknown quantity at this point
I have an LX coupe and had the Honda Dealership install a sunroof for me. I didn't go for the power one though because of the added weight and I really like having 3 settings of how high to put it as well if I want it out totally it takes like 2 seconds. I am very pleased with it, no leaks etc.... while I may get a wind deflector for it because at "very" high speeds it tends to whistle just a little. Hope this helps![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I say go for it!!!!
Old Feb 26, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
a moonroof is no replacement for a/c. if youve got the money to get one installed, get the a/c instead. i personally dont use a/c much, i got used to not having it in my 88 omni, only time it bothered me was when i had to sit somewhere not moving for a while on a really hot day
UltraHDGames
Jun 8, 2016 05:16 PM
beanhead
Sep 24, 2015 12:04 PM
bhollie
Sep 22, 2015 11:08 PM
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
