1987 K20 honda
Old Apr 7, 2006
exturbo6's Avatar
1987 K20 honda
I was checking out another site im a memeber of and i came across this..
I think the car is pretty sweet!
More info on the car...
http://www.redpepperracing.com/forum...pic=24296&st=0
Old Apr 7, 2006
eye_see_you's Avatar
let the devil out
give it a drop and that would be just a pure sleeper
Old Apr 7, 2006
DDragon7's Avatar
Wow, RHD.
Old Apr 7, 2006
Nick's Avatar
Formerly 2blu
Originally Posted by DDragon7
Wow, RHD.
wow, australia.
Old Apr 7, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
4 lug still? don't make sense
Old Apr 7, 2006
Sypher's Avatar
Sypher is a jewel in the roughSypher is a jewel in the roughSypher is a jewel in the roughSypher is a jewel in the rough
Wow, that thing much be a beast!
Old Apr 7, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
si axles?
Old Apr 7, 2006
exturbo6's Avatar
"Going by our 13.4 with 135 whp on street tires, and if we make 200 whp we're confidant we will run mid to high 12's on street tires. On slicks hopefully high 11's."
"We used integra da3 hubs and had custom shafts made by circuit worx. The car was tuned adjusting timing and fuel (no cam advance on current map as yet) for an hour and a half and it spat out 181 whp on a low reading dyno dynamics dyno. Lots left in it. Hitting the road with the car bad luck struck twice. First thirty seconds on the road we blew a CV. When replacing it we realised the mounts had sagged and the CV boots on both sides were rubbing on the control arms. And the rear mount let the engine move too much. We decided to try our luck as it was only just rubbing. Luck was not on our side. Just leaving to go to the track the rear engine mount snapped in turn letting the engine rock back and forth, resulting in the right hand shaft popping out of the gear box. The car is now back at the engineers workshop getting the engine raised and modifying mounts to suit at no cost. Could take a couple of weeks.
The positives. This is now the fastest car I've ever been in. The K20 in a 1560 pound car is fast. Can't wait to drive it again fully tuned." G AE82
this is from the guy who owns the car.
Old Apr 7, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
why doesn't it make sense? You gotta make custom axles to get it in there anyways, so why not just leave it alone. its not like its gonna shear off the wheel studs. Its a Honda, it still has no torque.
in response to the "drop it"
the K20 is so tall that its probably up that high so it doesn't smash the oil pan. Its a problem with the swap in the older cars.... the oil pan is the lowest point on the front end, and aluminum pans are "one and done" as far as scrapes go.
Old Apr 7, 2006
MajinB's Avatar
i was under the impression that you had to change to 5 lug or make custom axels.
Old Apr 7, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
no you can leave it with 4 lug or go thought the hassle of changing it to 5 lugs
Jessica Leung
May 5, 2015 05:12 PM
carid
Apr 30, 2015 07:00 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
