AC cutting in and out
Old Feb 18, 2006
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
So it was snowing again on the Grapevine section of I5 in southern california yesterday. I've never driven the civic into below freezing temps before. Anyways, i know that the AC doesnt work under below freezing temps. Now my question, how do you guys defrost the windshield in below freezing temps. While driving i had the heat and ac on, but the car started fogging up every once in awhile over the grapevine cuz the AC wasnt running. Any advice from people from snow country (Canada, northeast, north west). Ive driven in the snow many times before in our van to areas such as lake tahoe. Somehow we never had that issue of the ac shutting down or defrost issues in below freezing weather. So advice?
Old Feb 18, 2006
RHCP0801's Avatar
ughhhhhh i just blast the heat and turn the dial to the defrost setting, i never have the ac running during the winter and with the heat and defroster on it never fogs up at all, windows are always closed too
Old Feb 18, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
you gotta let the ac run till the fog goes away then turn the ac off.
Old Feb 18, 2006
DDragon7's Avatar
Same here, old cars didnt have AC and defog on so no point of turning it on when defogging, only removes humidity faster but uses alittle more gas and robbing the little bit of power that we have.
Old Feb 18, 2006
the heat should work fine. you need to angle the vents to the windows and use the rear defroster. it still turns the ac belt even tho the ac doesn't work (compressor).
General DIY
Sep 25, 2015 08:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
Mc7602
Sep 17, 2015 02:01 PM
EM2661
Sep 11, 2015 06:01 PM
redcloud
Sep 7, 2015 01:45 PM
