Why does civic sucks so much?
i think the civic power-wise is unsafe for roadways now. too many other fast cars and its very difficult to flow if you're flooring it and nothing happens especially on the freeway.
Originally Posted by chriz eryk
its a love hate relationship for me. but my civic seems to look better and better every day......u'll learn to appreciate it as time goes by.
cheers!!
cheers!!
Originally Posted by Jrfish007
All the cars you've listed have HUGE torque number compared to you 1.6L. Specially the TDI, I mean diesels are torque MONSTERS lol. I know, use them for hualing my horses, I would never bother using a gas engine. But the torque is going to help tremendously on the hills.
The torque is created by a longer stroke in the eninge, if you look at those engines compared to your civic engine, you'll see the engine stroke is much longer while the engine bore is much smaller. What does this mean, this means they have got a better engine than you at low RPMS, you need to bring your RPM's up higher than theirs to have a more comparable engine. So while they can shift at 3-4,000 going up the hils, you need to shift aroun 5,000 (just an expample).
Most people have this thing about how higher RPM's are bad for your car and that's just no true. RPM's won't hurt your engine, it's piston velocity you have to look at, and since for every rotation of the engine, you're civic is not goin as far, you can easily go to a higher RPM, while maintaining the same piston velocity as your friends there. Honda was orginally a motorcycle company, they are used to making engines that rev high, their car are simliar.
Cliff notes: they have a better bottom end while you have a better top end. Use the top end of the engine, while they use the bottom end.
Till now and after using some other cars/suvs , I've noticed the difference in the high/low RPMS on each car , especially at my other car VW Passat 1.8 turbo which is a monster in accelaration with low RPMS even though it's fatness and i'm not comparing it to the sweat civic..
What's bothering me is the fact i realy used 4-5000 up the hills and the car didn't accelarte enough , it keep howling and crying while these cars where almost silent and keep kicking :/
I don't know much in how to keep maintaining piston velocity in high RPMS's , Or maybe i just suck with this terms :/
Again , I realy appriciate your explaination and it somehow blows me some miths about my car which i have for almost 3 years :O
Originally Posted by TemjinX2
wait how do u lose to a 105hp mazda 3? Isn't that car like 2800lbs? 105hp mazda 3 vs 105 civic 2500lb?
solution buy a cheap d17a2...there like $500 and you get 127hp lol....
i bet you amazing mpg with a 1.6L though...lol.
keep in mind the Mazda 3 and focus are probably using the same basic engine, the Mazda probably uses slightly different heads to breath a little better, and comparing the climbing abilty of any diesel to a comparable sized gas engine is not fair, deisel is just a more powerful fuel. I don't know the exact specs on these cars, but I am guessing they all put more torque down than the civic, and when you are climbing that is important.
In short, if you are really interested in clmbing, take a look at the torque specs of each of these cars, you'll see the civic is lacking. Remeber it takes torque and hp to turn the tire.
Going a little more with the numbers; if you stay above 5252RPMs this is the majic number where hp becomes more important the torque for Hondas... kind of
If we look at this eqution, HP = Torque * RPM/5,252 you can see at 5252 RPMs, horsepower = torque. Above this 5,252 RPM, horse power will be greater than torque, so without having to look at a dyno on your car, I can tell (becuase I've had WAY to many Honda's
) that you really need to stay about the "magic number" of 5252 RPMs while these guys are making a ton of torque below hand. In other words, they're car is going to reach peak power (Power is HP*Torque=power in watts or Newtons) at a lower RPM because the have more torque to compinsate for the lack of HP. While your Honda will make it's best power at higher RPM's where it has HP to replace the lack torque.
It's complicated, but the point is to climb a hill in a car that has a lack of torque (as most Honda's do) you really need to get on the motor, and while it may sound bad having a car "screeming" at high RPM's, it isn't that bad if the car engineered to, like a Honda.
The next question is probably why did Honda od this? There are two reason, first is the low piston vrlocity at average cruising RPM's gives very good gas milage. The second reason is that when you are on a track, it is more desirable to have a car that has high RPM power than low torque power. For the most part, when on a track, you want to keep the shifting to a min because shifting waste valuable time. So having a car that has lagre power band is in vaualbe. And you can also control where in the power band you are and exactly how much power you are putting down, all of this is why Honda's often dominate their classes on the track.
Where can i get this chip via worldwide?
He's saying buy a new engine. You can get them shipped from Japan rather cheaply. I personaly would not go for a d17 if you are going to swap motors. to Impress your friends, get a 1.5L 3 phase VTEC engine. They do not have them here in the US, but in Japan and some parts of Europe they are aviable. They have around 150 hp, get around 40 miles per gallon (17 km/liter or 5.88 liters per 100 km) and have better lowend torque. The down side is that I don't know how to install these, and since most people that swap engines are in Japan or the US, there probably is not much info on this. It really depends on how Honda made the motor mounts in your car.
If you can get the enigne code from your engine, like B16A2 or something like that I maybe able to help you find a chip for your car. Here in the US we don't have that engine, but they may have it in Japan, and I know a couple of export/import place in Japan that can may be able to get you a decent chip. But the engine code is a must.
you all dissapoint me. just because your car comes with 127 hp doesnt mean it cant be fast. every get in a race where you do more than drive in a straight line? if you havent, then you should try it. em2's weight about 2400lbs. strip the trunk, add carbon fiber, lighter wheels, and a lighter exhaust and you've got yourself a pretty light car. now get some ***** and sling yourself around a corner.
He doesn't have the d17. he's got a 1.6L with 105 hp, different country different engine.
I just tought about it and i've came with the conclusion but at first here's some details on my car :
Honda civic 2001 , 1600ES 4dr , stock parts beside sp sport 490 tires and custum back lights , Perfect condition.
The problem is that as i've made a comperasion to other 1.6 engine or so year 2000+ cars , And mine seems realy slow!
As for an example i couldn't catch up to the follwoing cars during a realy ascending/descending road from tel aviv to jeruslem today:
Ford focus hatchback year 2003 or 2004 , 1600 engine(100 HP)
Mazda 3 year 2005 , Completly stock 1600 engine(105HP)
VW Bora year 2000 or 2001 TDI , 1900 engine(100 HP)
And there's so many more but those above are the most recent..
Even going onto a full therotelle , I stayed behind after a minute or two of a fight...
So i need so explanation since i'm realy realy pissed off!!
(((Also
If you want a fast civic, invest in a new engine (an no, not the d17a2) I'm talking k20a2 (acura rsx-s)... none of those cars will ef with you, but if they do, you'll own em. Now, turbo that k20 and you'll be perfect... sure im talkin a good 10+ grand.. but if you want a fast civic... thats what you need to do.
And whoever it was that said Mazda 3's are fast....
Don't quote me on this, but 7th gen Civics (Si not included) all came with a D-series engine.
cheers!!
cheers!!
Originally Posted by Sujak
I love my civic, 300miles on 10 gallons (all city, so thats not bad.... only 2090 miles on it, kinda heavey foot....) I like the way it looks, but there's still slower cars out there.
Drunken Master-7thgen Ninja
ok welcome to the site. i have family in Isreal. second, civics don't suck, they are great. just realize that it won't break like the focus or 3. and if you can scrap the money, and i know how hard that is, and get a swap.
If you or anyone else want to make your civic fast I highly recomend getting
Konig heluim 15" rims, they are 10.5lbs ea, make a big improvment over 17'd or the stock steels. The ITG air filter i have proven to make 3 more HP over a K&N filter. swap out your exhaust for a rsx exhaust.
Dont worry I can back this up after I hit the track soon
yeah its the engine the US civic uses. I meant it as a half joke cuz those engines are so cheap and slow too.
I would do a k20a swap.
Originally Posted by SimonTek
I have 5000 miles on mine. Its not even 2 months old.
And by the way, I'm not using it like I'm supposed to this semester. I'm driving it less.
Originally Posted by ramcosca
My guess here is that the code is D16-something...
Yeah, I'm guessing D16, but there is a special code for for the three phase VTEC versus the dual phase VTEC (like the one in the US) and yet a different code for the nonVTEC.
Many thanks for all the replies guys especially Jrfish007 , You guys seems to realy love civics it's realy great to see that!
IceVic05 , Please take notice these comparation weren't taken on smooth road as some other already noticed and see Jrfish007's explanation of the low torque.
I've asked a Mod "expert" company in my country for an chip for my honda and they said it will cost about 850 USD for additional 20+- HPS.. , I think it's preety expensive :/ , however must remember hondas are on the top of expensive japanese cars on israel as my car worth bout 14,500 USD which is almost a price of new civic on other countries i assume.
My engine is 1.6ES VTEC dunno more details , How can i check the engine code? i realy don't know much on mechanics and i use to take care of the car on official garages when i need service.
About taking the K20 engine replecment , I think it's too far drom reality and gonna be realy hard to afford/get and take care of on here
yeah, the low end torque is nice and quite, while the higher RPM of the civic (or rather Honda motors in general) sounds bad to some people, but it's just the nature of the beast and there really isn't anything we can do about it
Well, you don't have to worry about piston velocity, all you need to remember is that your car (or rather most Hondas) are built to handle higher RPM's than most cars.
Chip that will increase 20hp? Thats a scam I never heard of a chip that increases hp by 20 n every1 will tell u the same.
850 USD is a bit pricy, I would say anything more than $200 or maybe $300 if it say a genuin Mugen or Spoon, but I'm cheap. Anyway 20 hp is possible if this the engine I'm thinking of, but I'm not sure.
The engine code should be stamped on the block somewhere, generally under the heads and above the manifolds on the front of the engine. The easier way might be to look up the specs on the internet. I'm trying to look for the specs on a simliar car, but my spanish is not that good and it seems to aviable in latin America.
Anyway, yeah your car probably doesn't like the real high RPMs mostly because almost all Honda's have breathing problems. If you want a little more kick at high RPM's, get a cold air intake (CAI). You can look around this site for which ones people like the best. Stay away from short ram intakes because they suck hot air in and really don't help much, even though they are cheaper. For your engine, I would look to get stuff directly from Japan, I've ordered parts from here http://www.j-garage.com/ with good luck. They seem to be very knowledgeable, although their English is a bit broken, and they have a good selection of parts. But they will need to know what kind of engine you have, maybe they know what a 1.6ES VTEC is already, and that's all they need. But you can go to this mod shop you spoke of and ask them how much an intake costs and compare that to a couple of Japan shops. Then of course their is always Ebay, they work quite nicely, but you must make sure you are getting a name brand, there is alot of crap on Ebay that can hurt your car.
Intakes are faily simple to put on, if you have a screw driver and ratchet set, you can probably do it yourself.
