went to dealership today
Old Sep 27, 2005
  #31
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
im so annoyed.. im at the dealership now.. they have the new SI and the new ridgeliner (which btw is EXACTLY the same as the 05 with the exception of the rims).. they dont have the 8thgen civic... this sucks.. i wanted to take that ugly lil sucker for a spin..
the new SI is very nice though.. wonder if they will let me borrow it
Old Sep 27, 2005
  #32
Jrfish007's Avatar
Originally Posted by iwu
The line about Ford and only being able to use Motorcraft is flat out false, even in the manual it says you can use other oils as long as the oil is rated the same. You can even bring the Ford dealer some Mobil 1 and they will use that on your oil change.
However, if you are stupid like a friend I know who poured in 2 stroke engine oil then yes, they can deny your claim.
Read it closely, they say any thing OF EQUAL OR BETTER QUALITY. Since Motorcraft has some of the best dino oil around, really the only way to get better is to go with a good synthetic.
Some how I'm thinking that since two people sued Ford for it, and lost, that it is not false. Because the law says you can replace OEM parts with BETTER OR EQUAL parts. You can void your warrenty by replacing parts with lower end parts, in this case oil. If they do an oil test and find the oil was faulty because you used a poor oil choice and they have the test results showing the TBN and moly count and all that, you're screwed. Basically, you can't put worse oil in the engine and expect to run it for 5-6k miles and hold your warranty.
Old Sep 27, 2005
  #33
zen_master's Avatar
trust me, you will get used to it once everybody start driving it.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
martinsmartin
Aug 15, 2015 07:34 PM
Bonnabell
Aug 14, 2015 04:15 PM
OH5LXSE
Jul 28, 2015 12:21 PM
Hqly2001
Jul 25, 2015 05:32 PM
