dealer warranty- worth it?
Old Sep 12, 2005
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Hey guys I'm about to buy a used rsx that is past its factory warranty. Do you think it's worth it getting the aftermarket warranty? Is it any good? My neighbor says they (the warranty co.) always find a way to get out of paying for it.
Old Sep 12, 2005
CarbonFly's Avatar
It is worth it....my dealership has NEVER given me problems even when the problem was caused by my aftermarket modification they covered it.
List of stuff they have covered:
-CV Joints
-Axles
-Right rear wheel sensor (my fault)
-Right rear wheel sensor (24hrs after they replaced the first one...still my fault...still covered)
-ECU replacement
Not one damn problem at all!!! Go Honda!! BTW, I have the extended warranty too.
Old Sep 12, 2005
winnerpl's Avatar
This not a Honda warranty though.
Old Sep 12, 2005
kool-aid's Avatar
kool-aid is an unknown quantity at this point
Yup, listen to yoour neighbor. Aftermarket warranties are terrible. I had a friend who fried his tranny in his truck, they wouldn't cover it cause they said the parts inside had shown signs of heat, really, duh, heat is the number one killer of trannies. It's another money grab by the dealer.
Old Sep 12, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
i dont think its worth it.
Old Sep 12, 2005
if its the hondacare extended warranty, they will deny all claims. I have an aftermarket company (through a different carrier) and so far they replaced an alternator for free no problem. Cost $500 and I picked the shop to do it. The shop calls the company and they sent money. And I even had aftermarket pulley on the alt.
Old Sep 13, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Just make sure you do your research before you buy.
There's plenty of good info to be found here: Linkydinky.
Old Sep 13, 2005
Jrfish007's Avatar
If it's a used RSX, get the certified warranty. You don't actually have to buy a certified car to get the certified warranty, you can just take an RSX to an Acura dealer, tell them you want the Honda warranty to cover the powertrian. The power train warranty is worth the money. the bumper to bumper is through Hondacare, this has been bad to most people, just get the Honda certified warranty. If think it's around $800 plus parts (they charge you if they need to replace breaks and all that, so do the brakes your self if they need done).
Old Sep 13, 2005
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
I would look into getting an extended warranty from Honda/Acura instead of going with an aftermarket one. Generally aftermarket ones are picky (as mentioned), take longer to approve claims, and often won't use OEM parts either.
Old Sep 13, 2005
streetglower's Avatar
it all depends on who you go through. If you pick just some random company and dont research them, then you will get screwed over. But if you pick one thats good, you may not have problems. My car's 100K factory warranty ran out a few weeks ago and I purchased an extended warranty to 120K for $1200 that covers most everything. and this is one of the top warranty companies around. You can pick any shop to have your work done.
I say first explore the option of the dealership warranties, but then check out independent companies for pricing and coverage. Usually Most dealership warranty companies will cover 100% of whats on the car, as most aftermarket companies will cover a certain list of parts.
Old Sep 13, 2005
Jrfish007's Avatar
Yeah, lots over outside comapnies only cover certian parts of the engine. Like they don't cover the ehadgasket because it's not a lubed moving part, then if you blow your head gasket and kill your motor, you'r screwed, because the damage to the rest of the motor was caused by a fualty part that is not covered.
deanaZoom
35
Sep 19, 2015 12:22 PM
blward6
Sep 16, 2015 05:32 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
FistRock
Sep 4, 2015 08:00 PM
