civic specs
Old Sep 5, 2005
CiViCPrAnInG2k1's Avatar
civic specs
did anyone got that email from honda? i don't know if it has been posted, SI has been confirmed with a k-series, K20Z3.
Coupe/Sedan
• 1.8-liter, iVTEC® 4-cylinder engine
• Engine type and number of cylinders: Water-cooled in-line 4-cylinder
• Displacement (cc): 1,799
• Bore x Stroke (mm): 81 x 87.3
• Max. Output (horsepower)*: 140
• Max. Torque (lb-ft.)*: 128
• Compression Ratio 10.5:1
• Improved fuel efficiency
• Significantly advanced low rpm torque and top-end power
Civic Si
• 2.0-liter, DOHC iVTEC® 4-cylinder engine
• Engine code: K20Z3
• Displacement (cc): 1,998
• Bore x Stroke (mm): 86 x 86
• Max. Output (horsepower)*: 197
• Max. Torque (lb-ft.)*: 139
• Compression Ratio 11.0:1
*Horsepower and torque calculations reflect new SAE J1349 procedures revised August, 2004.
Old Sep 5, 2005
robbclark1's Avatar
Retired suspension supermod.
139 torque is shitty!
Old Sep 5, 2005
dirtySAMURAI's Avatar
I log in from time to time
so it IS a k20.
Old Sep 5, 2005
yes, a 2.0-liter, DOHC iVTEC® 4-cylinder engine K20Z3
Old Sep 5, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
so the next question, whats the diff between the a3 and the z3? besides the numbers
Old Sep 5, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The Z3 is true DOHC VTEC like the K20Z1. The A3 was variable intake lift only. My guess is the Z3 is a K20A2 with some minor change to the cam profile that warranted number changing.
Old Sep 5, 2005
02cvcEX's Avatar
02cvcEX will become famous soon enough02cvcEX will become famous soon enough
letters*
that's pretty cool... wonder if there's a k20z or k20z2 out there somewhere
Old Sep 5, 2005
booba5185's Avatar
hmmm, in that case i would if u'd need to change the cams or the entire head to reach z1 numbers
Old Sep 5, 2005
lol! nice try
Old Sep 5, 2005
genexrocket's Avatar
i jus got my car and driver a few days ago; and they already reviewed the Si with great ratings
Old Sep 5, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
Get out of the dark. Temple of VTEC has everything you want to know abou the Si, including some good powertrain info with regards to the naming scheme and such.
www.vtec.net
Old Sep 5, 2005
nindoo's Avatar
Why is my vagina bleeding?
Its more like a euro R engine.
The balancer shaft of the si is heavier than the The Type S engine resulting in a few less HP on the Dyno (Inertia). Its advatange is however it revs up smoother than the K20Z1. The transmission gears 1 through 5 are the same as the type S, gear 6 is taller and the final drive is the same of the 2005 Type S.
So its an improvement over the k20a2 or k20z1.
Old Sep 5, 2005
ok simple question. if you're driving a stick and let's say you're on gear 5. do you have to put it in gear 4, then 3, then 2, then 1, before going to a full stop and brake? or can you just put the gear on neutral whatever gear you're in then clutch brake right away?
Old Sep 5, 2005
K20me's Avatar
You can just go to neutral then hit the brakes. I personally go down the gears and use the engine to stop the car, then I apply my brakes.
Old Sep 5, 2005
thanks man. i always thought about that because everytime i drive a stick (uncles truck) i just put it in neutral then break when i'm about to stop on the light. never did i do the slowing down the gears.
Old Sep 5, 2005
ncirom2003's Avatar
never downshift into first, just dont
Old Sep 6, 2005
what do you mean? u mean the last downshift is at 2nd gear? does that also mean, never fully stop on gear 1? instead you put in neutral, fully stop, then gear 1 when about to go?
Old Sep 6, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
1st gear only meant for starting out, never downshift to first gear. As far as breaking i know I shift into neutral when coming to a stop, never ride the clutch. I guess downshifting fromt 5th,4th,3rd,2nd will work too.
ezone
24
Oct 30, 2017 11:27 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
LOWBOY
Nov 12, 2001 03:13 PM
2k2CivicEX
Nov 5, 2001 07:22 PM
silvervtec01
Nov 4, 2001 06:56 PM
