help!
Old Jan 30, 2002
cable's Avatar
cable is an unknown quantity at this point
help!
sup?
i tried unbolting the rear section of the muffler, but the bolts wont turn at all and i dont wanna stripe the nut, although i may have a tiny bit....i tried WD-40 and it didnt work...what can i do to unscrew these bolts?
thanks
Old Jan 30, 2002
cable's Avatar
is there something i can put on it to make it turn?
thanks
Old Jan 30, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
get some rustaway or some such lubracant. you can get it at any automotive store or home depot. alst try using a longer ratchet.
Old Jan 30, 2002
Mitchman's Avatar
Mitchman is an unknown quantity at this point
get air tools
Old Jan 30, 2002
Grey's Avatar
DIY King
WD-40 works fine for me all the time. I just spray a ton and let it sit. You might also use a socket set if you're using a wrench
Old Jan 31, 2002
cable's Avatar
thanks, i'll try it out
Old Jan 31, 2002
RiceBuRNeR's Avatar
Turbo Member
I needed an impact gun to get mine off.
