need some help
Old Jan 30, 2002
cable's Avatar
cable is an unknown quantity at this point
need some help
k, im in need of a new muffler, so i got the hp racing bolt on rear section to replace mine....
to install it, can i just un bolt my existing one and bolt on the rear section? it looks pretty high, so do i really reall need to lift my car up? cuz my friend has jack stands, but i dont wanna bother him...also, he said i have to work with some springs inside the rear bolt on, is that true? cant i just bolt it into place.
thanks
Old Jan 30, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i dunno about the bolting part but it would be a whole lot easier if you jack up your car. actually i think you have to anyway
Old Jan 30, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I didn't need a jack for mine, it was kinda a tight space but you should be allright.
Old Jan 30, 2002
CapYoda's Avatar
Escaped Convict
it'll definitely be a lot easier if u jack up ur car...
just get two jackstand (you should have one that came with ur car) and place it a the rear points.. just make sure u have it secure at a flat surface so the car doesn't just drop on ya... anyway becareful about it.. I wish i can give u more tips but I dont know if it'll be just a direct bolt on or not... hopefully it is so u dont have to weld anything on...
my suggestion, go take a good look at how the muffle is attached on.
Old Jan 30, 2002
cable's Avatar
thanks!
ya, ima try it w/o jack stands at first and worst comes to worst, i'll prop it up..
the muffler is a direct bolt on, onto the rear section...but is there a spring inside the piping? that's what my friend said...
Old Jan 30, 2002
avenger's Avatar
avenger is an unknown quantity at this point
does anyone else run the HP? Im gonna buy one, how do they sound w and w/o the silencer?[IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 30, 2002
civicpride's Avatar
civicpride is an unknown quantity at this point
why don't u take it to a muffler shop so they can weld it on?
