LED WASHERS
Old Jan 30, 2002
  #31
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
Here's how I did mine. I popped the turn signal bulb out of the headlight, remove the bulb, and unclip the harness from the bulb holder. Inside the harness are a bunch of holes that the leads from the bulb holder plug into. It was pretty simple to figure out which one was positive and which was negative. I fed the wires into the holes, put the bulb holder back in (it's copper leads effectively crimping the wires into the holes) put the bulb back in and that was it. If you do this, the leads for the bulb holder might push out when you plug it back into the harness. Just take a flathead screwdriver and push the leads back in so they seat properly, then put the bulb in. It's simpler than it sounds, and I haven't had a problem yet. If you take the bulb out and look at it you will see what I mean.
Old Jan 30, 2002
  #32
Cross's Avatar
Cross is an unknown quantity at this point
This should be in Tech....
Randy
h4ldol
Apr 24, 2017 08:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
