S2000 facts
Old Jul 5, 2005
  #31
S2000man01's Avatar
O RLY
yeah but since then another mag posted a 1.19
Old Jul 6, 2005
  #32
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Originally Posted by dre2600
Except that the engine of the new RX8 has proven notoriously difficult to boost and when boosted has only been able to take low psi.
The earlier 13B was really good at being boosted, despite the fact that it made a hell of a lot of heat and you had to overhaul anything even remotely related to cooling. The Renesis, not so much for the boost.
Where did you get this from? On 5-7 psi with the greddy kit and proper tuning results have varied between 240-300 whp depending on tuning and supporting mods. That's pretty good for "low" boost. The reason why nobody has been running higher boost yet is because the ECU is exceptionally hard to crack. It has nothing to do with the 13Brenesis vs the old 13B-REW. If anything the new Renesis makes power much more reliably and more power more easily considering the 13B-REW was making 255 bhp with sequential twin turbos running around 7 psi.
That's pretty good for a 3 grand kit, and there is an even better one coming out but it's 5k MSRP from speed force racing.
Old Jul 6, 2005
  #33
dre2600's Avatar
On an engine that already has 237HP stock thats unimpressive. And the videos I've seen, well, the video I've seen showing a purporedly turboed RX8 look rather uninspiring. I'm not saying its a bad engine, but I don't think it's strong point is FI, its more NA-based, and it performs admirably in that regard.
Preliminary turbo tests on the Mazda3 engine which only makes 160HP stock shows around 240-260HP at 7psi., all that from an inline 4 versus a rotary.
Old Jul 6, 2005
  #34
Zzyzx's Avatar
Autocross Junky
Best use for the Renesis engine Ever....
http://www.starmazda.com/index.html
one of my most favorit Racing series.
Old Jul 6, 2005
  #35
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
lol dont mess with nookiemonster. every post i've seen that has something remotely related to mazdas in anyway, shape, or form, he always jumps in and proves his facts.
Old Jul 6, 2005
  #36
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
yup hes the s2000man of mazda
Old Jul 6, 2005
  #37
RESIDENT ROTOR HEAD
Let me clarify. Due to the vehicle monitoring systems via TCS/DSC on a dyno, the car only dynos between around 180 whp. Some argue the car is not making manufacturer claimed hp, while Mazda argues that the car senses abuse and pulls power on a dyno. The M3 and Porsche 911 also experiences similar dynamometer oddities. The dyno arguments are a totally different story, but in stock form the car will do 14.5 in the quarter and a 5.8 0-60.
That being said 240-300 whp (WHEEL HP) is quite a jump. At 265 whp, that's approximately 312 hp on moderate tuning and low boost at the crank (calculating a 15% drivetrain loss). You have to remember that the current gains on the different turbo setups are achieved with a low pressure small turbo and a greddy emanage with little to no fuel mapping/delivery tuning.
So to say that the car benefits little from FI is a misconception being that you don't totally understand all the supporting systems. Alot goes into a FI setup and you have to understand the big picture. Rotaries have always made big power from FI and the renesis is no different. The car gains on average 80-90 hp from only 7 pounds of boost. Just wait until proper tuning via a standalone EMS is made available, and you'll see gobs of power.
FYI Mazda is currently developing a Supercharged Top Mount Intercooled RX-8. Check Speed Mag and Rotary News for more info.
Still, that is not what this car is about. The S2K is not about drag racing either.
So enough about the RX-8...this thread is about the S2K. Let's try to stay on topic
Old Jul 6, 2005
  #38
WhiteCastle's Avatar
want a drag car, get a GTO.only good in a straight line lol
Old Jul 6, 2005
  #39
diskreet's Avatar
we can always count on you to pwn people. thank you.
Old Jul 6, 2005
  #40
diskreet's Avatar
Yay some ignorant person left this as rep (neutral, prolly supposed to be neg.) for my snippit about rotaries being good to boost:
rotaries dont like boost dumbshit
real mature whoever did that. very very mature. grow up and get your facts straight. a rotary is EASY to boost and get power from since there is little engine work to be done. It makes alot of power with little size. Tuning may be harder cause most people don't have them, but there is almost nothing to mess up in the engine when you look at, and compare it with, a boosted piston engines.
nookiemonster can back me up: Are rotaries easy and safe to boost?
cliff notes: grow up buddy
Old Jul 6, 2005
  #41
RESIDENT ROTOR HEAD
Rotaries are far easier to boost for many reasons the most obvious one being that there is no valve train, and only three moving parts. So you can't exactly bend a valve or throw a rod. Heat breaks down apex seals though, so that's one thing you have to watch for. Heat can mean having to rebuild the engine.
Higher levels of boost can be done for the same reasons, but you have to remember detonation will also blow apex seals. Tuning is key with these engines as well as proper cooling.
The good news is that apex seals are relatively cheap, but if you don't know how to pull a rotary apart then you could be spending alot in labor. Rotaries are actually easier to work on than piston engines. My father used to do it on the coffee table. They actually get put together much like a sandwich.
If you want to see what I mean watch this video...
http://www.step-hen.com/rx8/files/renesis1.wmv
Old Jul 6, 2005
  #42
MyK's Avatar
MyK
MyK has a little shameless behaviour in the past
S2000 are junk anyway!
Old Jul 6, 2005
  #43
MajinB's Avatar
Drunken Master-7thgen Ninja
this guy needs to be banned. NOW. please s2k man do your modding job and ripp him a new ban. thanx
Old Jul 6, 2005
  #44
MyK's Avatar
MyK
^^^Wow, you've been a member officially for one month and your trying to ban people!!!
sure dude!!
Old Jul 6, 2005
  #45
dre2600's Avatar
I'm aware of all the things you said, I even dropped you a priv. msg. a while back looking for a press release or article about the dyno inconsistancies you mentioned so I could update an RX8 page on Wikiepdia. I didn't say it was a poor engine, I simply said the old 13B seemed better at what it did insofar as boosting was concerned. There appears to be far too many hurdles so far in tuning the RX8, its been out long enough now that somebody should at least have a fully functional turbo kit out, complete w. fuel mapping and all that, but nobody does. I don't want to jack this thread and talk about the Renesis, but it came up. I think its a great NA engine, but boost doesn't appear to be it's strong suit.
As for the supercharged MS RX8, thats still in the works, and I've got money saying it will be a v. mild supercharger tune, as w. all Mazdaspeed vehicles of late, that and the fact they don't want to be liable for what happens to a rotary when it makes too much heat.
Old Jul 6, 2005
  #46
diskreet's Avatar
yup. i used that vid in a presentation for my public speaking class.
did an informative about the benefits of rotaries. my teached drives an M3 and after that wishes she got an RX8 instead but she already got the M3 and said it was too late. lol.
thanks tho.
anyway
back to S2000.
Old Jul 6, 2005
  #47
ragingSPAM's Avatar
I just burnt my tongue
i wanna get a s2k...i have something special comming up for all of u to see....its a secret and will be revealed in a few years...u'll see
Old Jul 7, 2005
  #48
RESIDENT ROTOR HEAD
Oh I understand where you're coming from and I wasn't implying that you suggested it was a bad engine...I'm just letting you know the FI situation from my standpoint....EMS is the main reason I haven't gone boosted yet. I've been ready to throw money down on several turbo kits and nobody has impressed me yet. I'm very excited to see what speed force racing has to offer as well as HKS though.
As for the supercharged 8, I'm sure it's nothing a few new pullies couldn't take care of
Old Jul 7, 2005
  #49
S2000man01's Avatar
O RLY
sure dude!!
well you've been an @sshole for at least 10 years, so what's your point?
Old Jul 7, 2005
  #50
S2000man01's Avatar
O RLY
Yeah.... a 4 word sentence really shows us all just exactly how much you know about what you're saying.
Old Jul 7, 2005
  #51
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
i heard with a kit of some sorts you can actually raise the redline of a s2k to around 10,000rpm. s200man, any input?
Old Jul 7, 2005
  #52
dre2600's Avatar
Of all the things for the S2000 that float my boat, nothing quite does it like ITBs, heres the one that today has/is coming up w.: http://www.todaracing.com/products/h...le_bodies.html
Old Jul 7, 2005
  #53
S2000man01's Avatar
O RLY
10,500 so far i think is the most anyone has gone. you can actually do it fairly easily with a fairly inexpensive valve train mod kit.
Old Jul 7, 2005
  #54
QBoi's Avatar
Why should he be banned? Just because he gave us his opinion (ignorant though it is), doesn't mean he should be banned.
Old Jul 7, 2005
  #55
MyK's Avatar
MyK
Umm yea, ha ha aha, I've been an assh01e for atleast 10 yrs!! ha aha ahcough cough!
wow your lame! and you don't know me son, so dont act like you do!
Old Jul 7, 2005
  #56
MyK's Avatar
MyK
Dude, I was kidding, we all know there sweet cars!!! I'm a big honda fan, I drive an 04 si-g (CDN).
but don't get all defensive, I mean its one thing to like your car, but its another to be sexually attracted to it!
Old Jul 7, 2005
  #57
S2000man01's Avatar
O RLY
there's a difference between posting an opinion, and posting just to start crap and **** on a thread. leave the moderating to the moderators.
Old Jul 7, 2005
  #58
S2000man01's Avatar
O RLY
you're pushing your luck.
i suggest you don't post in this thread anymore. cuz you're really starting to **** me off. and i'm cutting you a break, so consider you and your mouth lucky.
the point of this thread was someone wanted to know interesting facts about the S2000. so far you've done nothing but ruin it.
Old Jul 7, 2005
  #59
S2000man01's Avatar
O RLY
sure dude!!
and you've been a member for not even a year and apparently think you can do whatever you want. grow up.
Old Jul 7, 2005
  #60
genexrocket's Avatar
i rode in my friend's s2k today, he redilined in 1st. man, it felt like a freakin roller coaster~!!!!
