200 horsepower w/bolt-ons
Old Jun 9, 2005
  #61
MajinB's Avatar
Drunken Master-7thgen Ninja
damn. good point. no plug wires. what then? bigger ignition coil maybe. don't know. i already have iridium plugs in it. you can feel a little difference. i needed to do a plug change and the iridiums were cheaper than the stock platinums. anyone else run iridium?
Old Jun 9, 2005
  #62
milba's Avatar
milba has a little shameless behaviour in the past
if you want to increase your car to 200whp with those mods...... rofl rofl rofl
soz i cant stop laughing
rofl....
tie it to the end of a 747 as it is about to take off
Old Jun 10, 2005
  #63
drjvic04's Avatar
drjvic04 is on a distinguished road
Okay heres the thing
You want 200whp right?
You must decide what you want to spend on this first, then the route you will go to get that(FI,N/A). No one else has done it without FI. If you want to go N/A, might I suggest that you find a hook-up with an experieced shop, or company and get sponsored. Thats about the only way and you might not even hit your goal. Study more about the D series engines and youll see that with a lot of modding d15, and d16 are pretty good when they are built right. Is the d17 in the same class...not yet but someone has to go there eventually and start it off.
Who knows it could be you
Peace
Old Jun 10, 2005
  #64
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
you're stupid. stfu
Old Jun 10, 2005
  #65
modoman's Avatar
ok this is how you get 200 hp from you d17a2. take everything apart. throw everything away. keep the block. take the block to a performance shop and expect to spend around $6*k easy for a full build. then you might have 200hp +
Old Jun 10, 2005
  #66
classact307's Avatar
classact307 is an unknown quantity at this point
Anyone wanting to change the stock Coil over plug ignition system is stupid, This system is able to produce enough availible voltage for up to 13.0:1 Compression, but then you aren't using pump gas. The reason there isn' t much aftermarket ignition products is because you don't need nething more, if you buy it you are just getting a name brand. You don't need more spark if you arent' getting more fuel, air or compression. Your car only uses what it needs, it has plenty more potential if you need it. If you plan on changing this system you better be running forced induction or you are just wasting your money. By the way... iridium spark plugs? You won't feel a difference. I run 50 shot all day...and there is no need for more spark cause this system puts out plenty. My buddies 04 SI with a jackson blower on it with 8 lbs, has plenty of spark with more in reserve. You guys need to learn how **** works.. not just replace it with an aftermarket brand (or RICE). All your buying is the name. Any questions ... contact me.
Old Jun 10, 2005
  #67
nindoo's Avatar
Why is my vagina bleeding?
you need a Cold Air Intake
Old Jun 10, 2005
  #68
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
well lets see if its an ex...
127 base hp
add:
Headers : 10-14hp
Exsaust : 4-6hp
intake : 4-6 hp
underdrive pullys : 4-6
fuel rail : 5-7
so right there we are looking at about 27-41 extra hp
127+27= 154
127+41= 168
So were still about 50hp off. humm add a cam +10, 40 off, ehh thats it. closes will make it is about 170. dang. oh well.
wait theres more.. 25 shot of nos!!! (Havent modifided engine yet, lets go for blow!) ha ha theres your 200hp. lol dont forget to change your oil.
Old Jun 10, 2005
  #69
joelwastaken's Avatar
joelwastaken is an unknown quantity at this point
k your numbers are a liiiiiittle off
heres more realistic for an ex:
~113 base whp
headers: 1-3hp
exhaust: 2-4hp
intake: 4-6hp
pullies: 2-3hp
fuel rail: i dont know what this does but probably 1-2hp on a d17
add a stage 1 or 2 cam to this and youll probably get ~15 more
but yea youre gonna need like 10 grand to get a d17 up to 200hp
Old Jun 10, 2005
  #70
Header!!! Not 2! ONE!.. How does a fuel rail at horsepower? It just stores more fuel and weighs less.
Old Jun 10, 2005
  #71
exturbo6's Avatar
~113 base whp
headers: 1-3hp
exhaust: 2-4hp
intake: 4-6hp
pullies: 2-3hp
ok i have everything listed but a fuel rail. i put down 122hp on my ex.
Old Jun 10, 2005
  #72
lol that sounds about right
do you have a new cam too? cause that shoulda put you a bit higher
but ya from what ive researched i/h/e/p is only gonna get you about 10-12whp
Old Jun 10, 2005
  #73
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
~113 base whp
headers: 1-3hp
exhaust: 2-4hp
intake: 4-6hp
pullies: 2-3hp
with 10 grand get a new motor k series
Old Jun 10, 2005
  #74
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
this thread is hilarious. Good luck man
Old Jun 10, 2005
  #75
There are some dumb people here...you all have luck with your high horsepower gains from your aftermarket fuel rails. Oh yeah... you don't need 10K to get a D17 up to 200 hp... you need $500 dollars for a nitrous kit with 100 hp jets...I'm not sure how long it will last.. but there is your cheap solution. If you want some real power ditch the fat girlfriend and the D17 and get a small block and make it rear wheel drive with a 4-speed muncie.
Old Jun 10, 2005
  #76
cosmo's Avatar
cosmo is an unknown quantity at this point
Ok paul walker.
Old Jun 10, 2005
  #77
i meant to get a d17 up to 200hp n/a youd need like 10k, so ya with no spray and no turbo or sc its gonna take some dollars
Old Jun 10, 2005
  #78
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
Even turbo will be difficult to reach 200 hp
Old Jun 10, 2005
  #79
Echelon04's Avatar
Originally Posted by cosmo
Ok paul walker.
LOL PWNED
Old Jun 10, 2005
  #80
CiviCoupe2k2's Avatar
CiviCoupe2k2 is an unknown quantity at this point
We have a winner for "Thread of the Year!"
And no i did not read all those pages...
Old Jun 10, 2005
  #81
S2000man01's Avatar
O RLY
lol is that your answer for everything? get a small block?
Old Jun 10, 2005
  #82
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
127 base hp
add:
Headers : 10-14hp
Exsaust : 4-6hp
intake : 4-6 hp
fuel rail : 5-7
127+27= 154
127+41= 168
X hp + Y hp + Z hp does not equal XYZ hp.
Old Jun 10, 2005
  #83
doubledeuce2k2's Avatar
i'd try getting rid of the d17 and throwing in a... KILL YOURSELF!!
Old Jun 10, 2005
  #84
dj02's Avatar
i got some stickers that will get your car up to 200hp :P
Old Jun 10, 2005
  #85
PoorCollegeBoy's Avatar
Stolen digital camera = no ninja picture for me
PoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the rough
How about you just accept defeat, build your car to handle and participate in some REAL racing events like autox.
Old Jun 10, 2005
  #86
never! its hard to give up when every day you mash the gas and nothing happens. We want a faster civic!
Old Jun 10, 2005
  #87
Well when your first car was a 1990 Toyota Camry, 4 cylinder, with an auto transmission you find yourself being content with a 2003 civic ex manual
Old Jun 10, 2005
  #88
ha yea my first was 87 jetta. i think the civic is faster? even tho jetta had a bigger engine, it didn't feel fast.
Old Jun 11, 2005
  #89
MajinB's Avatar
my first car was a 89 buick park ave. 3.8 v6 160 hp and 220 torque. this turned out to be a funny thread. thanks for the person who said good luck. i need it. but anyway, i was saying a new fuel rail would be needed if you slapped a turbo on something. i would think you would need a better ignition system with a turbo or super charger. my civic is the second car i have owned. and no i won't give up. i have a mechanic already. just need the green. if i was a rich kid it could be done, but then again if i was rich i wouldn't drive a civic, well maybe.
Old Jun 11, 2005
  #90
~113 base whp
headers: 1-3hp
exhaust: 2-4hp
intake: 4-6hp
pullies: 2-3hp
Your talking wheel hp.. Im talking engine hp. Hince the stock 127 hp. Your never going to get a na D17 with 200hp helll no. You might get the engin up is what i was saying. and nahh it wouldnt take like 10 grand. More like 3 to do it all.
