Downshift 5th to 2nd?
Old Jun 5, 2005
Vinh's Avatar
Just curious what would happen?
Old Jun 5, 2005
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
try and see what happens..
i have an auto, so i wouldn't know
Old Jun 5, 2005
shmik1's Avatar
yiiiiiiiiinnnnnnnnnnggggggggggggggggggggggg
a friend of mine showed me how the rev limiter works, on his old 95 hatch..
kinda funny cause his dad is a mechanic, and he works on motorcycles and stuff, he said "it's a honda, it can take it"
Old Jun 5, 2005
vietstylez's Avatar
what do u mean what would happen.. your rpm's would shoot way up depending on how fast u were going and if u are over 60 mph u have a good chance of blowing your motor
Old Jun 5, 2005
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
hahahahaa...I did that before but I was red lining 3rd and thought i put it in 4th but it went into 2nd instead...hahaha...it bounced off the rev limiter for about 3secs
Old Jun 5, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
haha, I do that once in a while, but mainly b/c the engine is going at around 1600RPM/40MPH when I'm in a bit of traffic; then traffic clears up. It's actually kind of fun if you can match rev and just take off.
Old Jun 5, 2005
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
under about 40mph nothing, over that and you get to see the inside of your motor on the highway.
Old Jun 5, 2005
^^^^ I once did it at 60MPH (to try to explain gearing and manual tranny to a friend), I was still fine.... RPMs were just below redline.
Old Jun 5, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
exact same situation as mine, but in my case i burnt the first o2 sensor
Old Jun 5, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
um theres no problem in doing that if your in the right mph, if your over then you have a problem.
Old Jun 6, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
went from 3rd to 2nd at around 55-60(usually I can hold 2nd till about 60) when I was about to race a TC last week. Bounced off the rev limiter and quickly shifted back to third. Everything seems to be alright.
Pissed me off though. Since I was right around 60 I guess it wasn't too bad, thanks to the rev limiter.
Old Jun 6, 2005
S2000man01's Avatar
O RLY
Here's the problem.
If you're OVER 60mph, like racing.... lets say redlining 3rd gear and shifting to 4th, but instead you accidentally shift to 2nd? It causes what's called a mechanical overrev.
No amount of rev limiter in the world will prevent this. You mechanically force the engine to overrev way beyond redline, and you can kiss your valvetrain and engine goodbye. Several THOUSAND dollars at LEAST to repair. It's a very VERY expensive mistake. And no.... it's not covered by warranty. And YES, the ECU/PCM in the civic WILL record a mechanical overrev so the dealership will know you've done it.
Old Jun 6, 2005
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
Over at Bimmerforums we call that the "money shift". No need to explain the "money" part.
I've heard of this happening quite frequently; redline 3rd, shift to 4th.....BAM and you accidentally shift into 2nd. Not a pretty sight.
So you say, oh no worries the rev-limiter will catch it. Wrong. If you are going to fast for the gear you shifted in, your motor will still spin waaaay higher than it supposed to be.
One method to prevent this is to back hand the 3rd--4th shift, or the down shift from 5th--4th.
edit: S2000man01 beat me to it!
Old Jun 6, 2005
vietstylez's Avatar
hmm..backhanding it eh? never thot about that i think im gonna do that from now on
Old Jun 6, 2005
R3DL1N3's Avatar
Here's the problem.
it seems kinda hard to miss 4th coming from 3rd, but i guess if you just plain sucked at driving a manual it could happen.
Old Jun 6, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
probably not much of a help because all the pics are down but I Read about this a few years ago
http://forums.beyond.ca/showthread/t-16883.html
read the discriptions of the picture and it should get you an idea
heres a video I think its from 4-3 but you can hear it misshift
http://rsx.clubrsx.com/videos/RSX-S_misshift.mpeg
Old Jun 6, 2005
rednothing's Avatar
rednothing is an unknown quantity at this point
Few years ago, I had a friend with a 92 teg gsr...he was on some open road in texas doing over 110 in fifth...went to downshift to pass another car (why he would need more power at that point to pass her I have no idea, but whatever) and he missed fourth and hit second...he blew his engine, his car broke loose, flipped over the k-2 median, over the opposing three lanes (he's lucky it was around three am and there was no traffic) and flipped and rolled 500 feet into the field nearby. His right arm and his brother's (passenger) left arm both went up through the sunroof and were crushed...my buddy's is still paralyzed and his brother got his thumb severed off...they found it 65 feet away and had to reattach it....among other injuries...anyways....you have fun with the downshifting and let us know how it goes.
Old Jun 6, 2005
S2000man01's Avatar
O RLY
you'd be amazed how often it happens on s2ki with the S2000. as fantastic as the gearbox is, it makes it too easy for not-so-skilled drivers to throw it into 2nd instead of 4th since the gates are so close to each other.
Old Jun 6, 2005
oh dear God.... just thinking how fast the engine wuold be spinning (if it were possible) at 110 in 2nd gear. yikes!
Old Jun 6, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Here's the problem.
Yea, you can kiss those parts goodbye if you let it go and don't quickly pop it out. I did this to my car... hit about 8500 rpms, then popped it out... Blew the header/downpipe gasket into peices...
Old Jun 6, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
you could probably see some stuff poking out of your engine and through your hood
Old Jun 6, 2005
beastiek2's Avatar
This cost me 1500 points
beastiek2 is an unknown quantity at this point
Did it on my boys 04 SI..Blew his motor right away...
Old Jun 6, 2005
Mike4831's Avatar
Mike4831 is an unknown quantity at this point
Well our cars will do 50 in second gear, so if your doing under 50 in fifth and shift, nothing should happen.
Old Jun 6, 2005
Zzyzx's Avatar
Autocross Junky
You guys may want to read this to understand proper shift leaver usage...
http://www.turnfast.com/tech_driving...shifting.shtml
Old Jun 6, 2005
HondaLuver's Avatar
Its a celebration bitches!
i down shifted from 6th to 3rd, nothing happened, just rpms climbed and i took off..
be careful, make sure your foot is always on the clutch..lol
Old Jun 6, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
I want my next car to be a manual, but this thread has got me spooked. Is it really that easy to F'up? Keep in mind, I've never driven a manual.
Old Jun 6, 2005
you destroyed your friends motor??
Old Jun 6, 2005
S2000man01's Avatar
O RLY
no. it's people who drive like a tool and dont know what they're doing that do such a thing.
Old Jun 6, 2005
Vantage's Avatar
Vantage should not be trusted
Wow, u must really suck at driving if u do that. Ive missed upshifting b4, but that just bounces off the revlimiter, nothing major, but downshifting, even if ur double clutching/matching rev's, u really shouldnt be doing it if u dont know ur RPM's...
LoL
Old Jun 6, 2005
Al Gore FTW's Avatar
jdmtytedoridori
dx/lx/vp manual trannies can do about 65ish in second
