Now This is the mileage I want
Old Jun 1, 2005
pr0vidence's Avatar
pr0vidence is an unknown quantity at this point
sorry no pics or proof, you will just have to take my word for it. I keep track of my gas mileage every fill up, I take the number of miles driven since last fill up and divide it by the number of gallons pumped.
this morning when I filled up the average was 51.5 MPG
there has been one other time when my civic (EX, 05) got 55 MPG, I wish I knew what the circumstances were for that kind of mileage, because I would love to get that all the time.
I wasn't even driving it light or anything, I was actually reving it up pretty good getting on the highway and stuff.
Naturally, you don't have to believe me.
Old Jun 1, 2005
CivicsRdBest's Avatar
was it a lot of highway driving? maybe you forgot to carry a number...
Old Jun 1, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
were you drafting? hehe. miscalibrated fuel pump from the gas station is usually the culprit for pumping too much or too little fuel into a tank. just check your gas milage next time, ifyou get a poor mpg with similar driving habits, you probably didnt pump enough gas into the tank which explains the high mpg. if you get a consistent high mpg, then congrats.
Old Jun 1, 2005
you sure you're not driving a hybrid..? i mean, the sedans look (almost) the same and all...
if you drive a coupe, this post is useless...
Old Jun 1, 2005
pr0vidence's Avatar
haha, good suggestions guys. I did do a fair amount of highway over that tank, but not much more than normal. I am positive it's not a hybrid. I was not drafting (actually studies have shown drafting really doesn't save you enough gas to make it worth it). The gas pumps here have the locks that you set when you are pumping and it pumps until it's full and auto shuts off without user intervention. I always just set the lock and let it pump itself until it auto shuts off. Meanwhile I am sitting at the ready with my pen and pad waiting to record the gallons pumped so I can do the division.
I can post the numbers if you want to check my math.
Like I said it managed 55 once before as well. I don't know why it's not consistent, just once in a while I guess. Normally it averages closer to 36 MPG, which is good, but 51 is better
Old Jun 1, 2005
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
I've gotten 50MPG when it was all highway and I stayed close behind other cars or most of the way. It's not unheard of, just really hard to do if you mix in any city or "non-draft" driving.
Old Jun 1, 2005
ctv's Avatar
ctv
ctv is an unknown quantity at this point
i got over 45mpg when i drove from MD to FL with the ac on, in my 04!
Old Jun 1, 2005
pr0vidence's Avatar
well I guess it's not that much of a fluke then!
some of it was with the AC on. I don't know about you guys, but I have not noticed that using the AC in my 05 affects the mileage that much.
Old Jun 1, 2005
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
I do a lot of highway driving and usually average around 41.5mpg in my 2003 Ex Coupe M/T. I thought it was a fluke the first time, but it can't really be a fluke if it happens every time, now can it?
Old Jun 1, 2005
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
I hit 40.8 ONCE
Old Jun 1, 2005
typeRDreamer's Avatar
typeRDreamer is an unknown quantity at this point
I WANT MY HONDA BACK!!!!!!!!!!!!!! I used to do 120 miles on empty in my LX.......
Old Jun 1, 2005
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
i cant even keep track of my mileage because my fuel meter keeps dicking around. one day id pump full and its go 1/4 down the next day. then slowly go back up to full
Old Jun 1, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
I'm calling BS. Its not that I don't believe you, but I think you've been duped. Something is definately up with either the pump you filled up with, or your odometer. This is much more likely than actually achieving this mileage.
Old Jun 1, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Chances are at 50 or so MPG you were doing some highway driving (alot) with a tail wind. My wife and I drove to Tennessee from Louisiana and managed to average 40+ mpg in her lx sedan with luggage. On the way back down we averaged 30 - 35 mpg because we were driving against the wind. That's probably the best explination for your occurences.
Old Jun 1, 2005
mrchowmein's Avatar
that could be it, the tailwind, ive seen on some insight forums that ppl get 100+ mpg going with the tailwind running in the hybrids lean mode. 40mpg is not a surprise tho, many many ppl have gotten 40mpg out of a civic, weight actually helps the civic, not the other way around, without weight in the trunk, the car bounces around have more trouble keeping speed, each time ive gotten 38mpg or above my trunk was full.
Old Jun 1, 2005
Jrfish007's Avatar
I think there was a pump issue. Either 1. the pump gave you more gas than you thought or it showed (in which case you got some free gas), and yes this does happen, I used to go to this gas station all the time and I was getting around 40+ with my civic, then one day I only got like 35, I went in to buy some stuff and the owner was there. I talked to hime and he said his pumps where giving to much gas out and he's lost over 10k because of it. OR option 2. different pumps have different "shut off" points. It can vary with in the gas station it's self. The auto shut off is not a reilable point to measure by , it can vary by up to half a gallon, but that still puts you in the upper 40's which is still very good.
Old Jun 1, 2005
neocivic01's Avatar
the Rage
neocivic01 is an unknown quantity at this point
i think someone forgot how to do basic math
Old Jun 2, 2005
pr0vidence's Avatar
You guys could be right, maybe the pump is lying to me. I also find it tough to believe my that just feels like being really efficient on occasion (though it would be nice).
So I don't know what happened.
Old Jun 2, 2005
higher numbers than 40mpg are only likely with an HX or hybrid. I can't possibly see an ex getting more than low 40s with all highway. Most my auto has ever gotten was 38mpg at 65mph all highway miles. Manual would get a few higher, but not 55.
mgrantaz
General
May 2, 2022 05:40 PM
robjcivic
Mar 12, 2017 12:10 PM
jtcavey
Sep 30, 2015 02:18 PM
hondacivic0253
Sep 29, 2015 08:06 AM
jsmithe2010
Regular Maintenance
Sep 25, 2015 08:15 PM
