k20a2 turbo vs. srt-4
Old May 18, 2005
  #31
jjdawg22's Avatar
jjdawg22 is an unknown quantity at this point
K20A2 + turbo = more power than SRT4 with bolt-on's. Also, the Vic is gonna weigh a little more. Wheter he has LSD or not should be irrelevant because you would definately have the advantage.
Old May 18, 2005
  #32
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
SRT-4s are just small fish in the sea and aren't in the same league as a car with a boosted K20. Boy am I gonna get flamed for that statement! Anyways, boosted K20s should be compared to WRXs, EVOs, GTs, etc.
Old May 18, 2005
  #33
WhiteCastle's Avatar
Originally Posted by pwr2thaboost
SRT-4 would smoke u silly... srry man.
ya modded srt-4 will own you. Know one on this site will admitt it sorry buts its true
Im a non bias owner seeing I love both american and jap cars..
Srt-4s stock 233hp
275hp they put in new injectors and some other stuff
turbo upgrade they crank out 300hp
hes most likely stage 2 kit witch is 275hp
Old May 18, 2005
  #34
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
if you compare stock srt-4 to a turbo k20 set at low boost (lets say 6) you'd still walk on the srt-4 anyday.
plus you weigh around 300 lbs lighter than an rsx if your do the engine swap on your 7thgen.
Old May 18, 2005
  #35
Srt-4s stock 233hp
A Stage 2 kit on a K20A2 is makin 325+ whp. A number of K20A2s are runnin the CN kit.
Old May 18, 2005
  #36
Got Boost???'s Avatar
My buddy has an srt-4 with a mopar turbo, short shifter, and exhaust.
We need more info, the only Mopar staged upgrade is Stage 3. But even that would have a hard time pulling a K20 turbo in a 7thgen
Old May 18, 2005
  #37
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
by the time you get everything done, he'll probably have more stuff done too..
Old May 18, 2005
  #38
dre2600's Avatar
the rods are the weak point when you raise the rev limiter. the stress caused by turbo is much different than the stress caused by higher revving. it's a completely different force. higher revving causes an exponentially larger amounnt of stress, largely due to piston deceleration, rod angle, etc.
I'm aware that the forces are different, but I figured that the rods were just generally weak, I was unaware they were forged, I thought only the S2K had forged internals.
Old May 18, 2005
  #39
AJ Quick's Avatar
AJ Quick is an unknown quantity at this point
I can't say for the guy.. but there are 2 stage upgrades, and a 3rd coming up sometime soon.
The stage 1 is injectors, and a computer, and that increases power to like 260 HP, and the stage 2, is (I think) another computer, with toys.. and a larger turbo. Good for like 300 HP. (I assume the friend has Stage 2, if it has a different turbo).
The stage 3 when it comes out is est at 350 hp.
These are pretty good upgrades that you get installed at a dealership, and still are covered under your factory warrenty.
Old May 18, 2005
  #40
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Iceburgslim was running @24psi and running 11.5's in the quarter, I dont know all of what he had done the to internals but he had a k20. That thing is sick.
Old May 18, 2005
  #41
diskreet's Avatar
the best bet is get your car tuned by a true pro, and then just race it.
The better the tuner the faster your car. And if they are really experienced they might just get you that extra 10-20 horses you couldnt get with someone newer.
Only thing; 11:1 compression ratio with boost = pretty big problem. I would suggest lower compression pistions, like 9:1 or 10:1 depending how much boost you want to run, and new rods are a must. Get a very breathable exhaust and you should be fast fast fast.
or.....Get the Jackson Racing supercharger (race version with upgrade boost pully) and only race him from a stop. All that torque and boost will make your 7thgen pull like crazy.
Old May 18, 2005
  #42
I hope you understand that the power numbers you are stating are at the flywheel, not the wheels.
Old May 18, 2005
  #43
His car was probably the quickest 7th Gen Vic on this forum.
Old May 18, 2005
  #44
criminal's Avatar
criminal is an unknown quantity at this point
go with an sc61 or sc63....go from a roll and it wont even be a contest
Old May 19, 2005
  #45
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
it's a joke poking fun at the neon. it has the worst risidual value of any car. If you buy a brand new SRT4 for $20,000, in a mere 5 years it is only worth about $4000.
ah, IC. too bad for the neon
Old May 19, 2005
  #46
S2000man01's Avatar
O RLY
Even the D17 civic has forged rods and a forged crank. The S2000 just has MORE forged parts, that's all. plus different design, etc.
Old May 19, 2005
  #47
orion_squall's Avatar
mmm,
it would be pretty hard for you to win, SRT-4 is purely made for straight line.
Maybe you can try race at a close course? That would really be racing.
Old May 19, 2005
  #48
Alex1's Avatar
SRT 4 has a lot of torque
Old May 19, 2005
  #49
Michalo187's Avatar
Abortion Survivor
Well who would win an Srt 4 stock or a D17 civic on 8 psi with greddy emanage tuned also streetlite flywheel and some other little bolt ons?
Old May 19, 2005
  #50
S2000man01's Avatar
O RLY
your point? just because a car has more torque means absolutely NOTHING.
Originally Posted by orion_squall
mmm,
?? hard to win? with the mods listed, the K20 turbo civic wouldn't hardly have to try.
Old May 19, 2005
  #51
nickm748's Avatar
^explain
Old May 19, 2005
  #52
ACURAwerx's Avatar
aren't people on club rsx at around 9psi running high 12s, low 13s?
Old May 19, 2005
  #53
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
as one of the morons of srtforums once said srt4>god...idiots
Old May 19, 2005
  #54
We still have to be humble here.
Of course the SRT-4 is a purely stupidly straight line monster. An Honda Integra, S2000 are more sport race course oriented car. The straight line race is not that much of our category at first place. THerefore, we still can't just underestimate the enemy. Still need to be careful.
Old May 19, 2005
  #55
BlackFire's Avatar
BlackFire is an unknown quantity at this point
The SRT-4 is 230hp stock. That would be around 198WHP, not to mention the 250lbs/ft torque (STOCK). With 14psi I'm sure he have to be over 300hp EASY and over 325lbs-torque too. Do you have any idea how much boost you need to have a K20 over 300lbs-ft of torque??..... With the mods you've mentioned he have in his car, I doubt you could beat that car with 8psi on a K20A2 on the 1/4 mile. Not even talk about the 40-100 race; SRT-4 are fast as hell on rolled drag racing. Remember that Drag racing is all about torque, not about horsepower.
Old May 19, 2005
  #56
S2000man01's Avatar
O RLY
lol, do you have any idea that 15psi is the peak boost a stock SRT4 makes? So how is it making 300hp with 14psi?
I don't think people realize. A neon srt4 running 17psi boost can run maybe a 13.6. A k20 powered civic running 8psi could likely run 12's. that's why i'm curious why people think a near stock SRT4 is going to beat a K20 boosted civic?
and again, torque is a completely useless factor if you just go "well this car has this much torque so it will win". if that's the case, explain how a stock 153lb/ft S2000 is faster than a 302lb/ft mustang GT. Why? Because torque in and of itself is completely useless. You must look at power band, gearing, weight, etc. All of those things matter JUST AS MUCH as torque.
Old May 19, 2005
  #57
S2000man01's Avatar
O RLY
Yup. and the civic would be just a bit faster because it's a bit lighter.
Old May 19, 2005
  #58
S2000man01's Avatar
O RLY
I understand. but a car capable of high 13's vs one capable of high 12's is a MASSIVE difference.
Old May 19, 2005
  #59
1320Racing's Avatar
1320Racing is an unknown quantity at this point
Ive seen an RSX-S with a reflash pull away pretty good from an SRT-4 with I/E. Pretty much stock but still. Thier is a Type-S here running 10psi and pushing over 300whp Jetblue can vouch for this. I'll put my money on a boosted RSX vs. an SRT running a lousy 14pounds anyday. Even if the SRT pulls out of the gate by the time their out of second the RSX is reeling by him no prob.
Old May 19, 2005
  #60
BlackFire's Avatar
I believe you should have a trip to Puerto Rico and see how are the SRT-4's here doing at the tracks.
But I forgot about something, here we do have an '04 RSX-S running 11's and it's a street car. But I don't know at how much boost and don't know about other mods.
