Idle problems?
Old Jan 20, 2002
TeamStylesRacing's Avatar
TeamStylesRacing is an unknown quantity at this point
Idle problems?
my car has been having a problem with the idle for a couple of weeks now. i took it in to the dealership and they said it's because of aftermarket parts (AEM sri), but i have had my intake for like 4 months now. i also adujusted the throttble body if that might be thr source of the problem. its been so bad that my car even stalled (my car is automatic!!). just wondering if anyone has had the same problem or know what is wrong?!? thanks
Old Jan 20, 2002
blouisgod's Avatar
Life Begins > 6800rpms
my idle was to high for my manual. i went to the dealership and they ddint know what was wrong. you need to reset the ECU after you put some mods on that will mess u p the computer. just disconnect the - battery cable for 15-20 minutes then put it back on and run your car at idle till it warms up to normal temp. then, take the car around the block for a few times, come back, and let it idle for a little more. your ecu will adjust and within the next few days return to the original factory idle point.
Old Jan 20, 2002
KurupTLX's Avatar
KurupTLX is an unknown quantity at this point
If you adjusted your throttle cable then that was the problem...
It should have nothing to do with your SRI
K-lx
Old Jan 20, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
what he said up there
Old Jan 20, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Here's a TIP,
After every engine related mod you do to your car... you always have to reset the ECU or it can harm you fuel management system and various stuff... by doing so, the ECU can set itself up to perform at it's best with your mods... my friend's Type-R had been eating a lot of fuel since he got an exhuast and intake... but that problem was fixed after we reset the ECU.... Good thing our cars take regular gas..LMAO
Old Jan 20, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
acutally...the word on the street (or among us) is that you don't need to reset the ECU...its the throttle cable adjustment you made...that can mess w/ the idle.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
