Help Please ASAP
Old Apr 24, 2005
guyincanada's Avatar
guyincanada is an unknown quantity at this point
Help Please ASAP
I live in Canada and we are required to have DRL in our cars. I took my civic in to get a new deck put in. When I drove away the following happened:
1. The dRl indicator was on.
2. Neither DRL is working.
3. Both Drl fuses are blown.
I replaced the fuses, but they still dont work. The stereo people said it has nothing to do with them. Its a problem with the car. They said the setero wiring has nothing to do with the lights. What should I do? I have been there countless times. Daytime running lights
Old Apr 24, 2005
hotrodcivic2004's Avatar
my civic has no boost
check the relays too, those might be bad.
Old Apr 24, 2005
CraigW's Avatar
Did the fuses blow again ?
Do the parking lights and dash lights work ?
Old Apr 24, 2005
how do I check those? I see them in the hood, but then what?
Old Apr 24, 2005
all the other lights work, and the fuses did not blow again
Old Apr 24, 2005
pon55's Avatar
Try resetting the ecu!(unhook the battery for a few minutes!
Old Apr 24, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
they are required to document all the visible problems with the car when it comes in. If they didn't document that before they started work on it, it is their fault, and they are required to fix it.
Old Apr 24, 2005
pon55's Avatar
^^^ In ya dreams!
Old Apr 24, 2005
Blahman2's Avatar
That should only work for a few minutes. If the light comes on all the time when the car is turned out. It'll do the same until the process is ignitiated.
Old Apr 24, 2005
actually one of the fuses has blown again
Old Apr 24, 2005
Blahman2's Avatar
btw... whats DRL?
Old Apr 24, 2005
dacivic's Avatar
dacivic is an unknown quantity at this point
drl=daytime running light
maybe take it back to the dealer?
Old Apr 25, 2005
CraigW's Avatar
Both small amperage fuses are feeding into the control unit for the DRL, I think I would be consulting the installing company on this matter.
