Coilovers or springs: need everyones opinions!!!!
Old Jan 18, 2002
blouisgod's Avatar
Life Begins > 6800rpms
Ok, the forum has been down and i have been dying to ask this question: Coilovers or springs!?
1. which one does/n't necessitate the use of aftermarket struts?(even though it is a good idea to get them cause the stock rate is too soft)
2. what is the ride quality and handling for each one?
3. should i just wait and buy a full coilover suspension?
4. camber kit is a must, correct?
Old Jan 18, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
1. both will probably blow your OEM struts
2. springs=quite smooth coilovers=loud pretty stiff
3. why?
4. no
Old Jan 18, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
Ground Control it work pretty good with your stock strut and the good thing is, your in control with your ride height
Old Jan 18, 2002
spoiledsteph
Guest
Posts: n/a
Coilovers will allow you to adjust your ride height, depending on what you want...with springs, you only get what they say. BOth will probably blow your struts...coilovers give a kinda harsh ride i think, but i would go for the coilovers if you want a drop of 2" or more. Just my opinion
Old Jan 18, 2002
KurupTLX's Avatar
KurupTLX is an unknown quantity at this point
Theres a lota ppl on here with eibach springs (prokit and sport line) without blown struts...
I think the blown struts are mostly from the worse names and garbage like MatriX coilovers
Im personally going with EIbach Sportlines as soon as April gets here n thers a lil warmer weather... ground controls were my initial choice but i decided on a height... so i dont need coilovers
K-lx
Old Jan 18, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
I just ordered progress springs, well last tuesday, and they claim a 2.0 in drop, we shall see though...
Old Jan 18, 2002
aznboy808's Avatar
aznboy808 is an unknown quantity at this point
i just getting normal springs for now....full coilovers would be sweet, but i'll wait on those.
Old Jan 19, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
coil over are the way to go. You can lower or raise...... that's the best part about it and it's really cheap for the setup
Old Jan 19, 2002
2k2civic's Avatar
obviously, not everyone here is as educated as I am, so I'll share....
Coilovers aren't made so that you can have an adjustable ride height - that's only an added bonus. Coilovers are made so that the springs can be adjusted and equalize weight distribution to the tires to aid in handling. If you want to go for looks only, then go springs. If you want performance, then I would say coilovers.
Old Jan 19, 2002
mykel115's Avatar
I second 2k2civic. Well Thats the good thing with coil over. Because if you have a spring and sometimes weight are not distribute equally. For example the left hand side springs both rear and front are lower than the right hand spring. Answer: Driver side is most commonly seated that way all the weight are distributed on the left hand side of you car than the right. Overtime your spring on your left side get softer than the right side of your car. Another example Rear right spring is lower than all three springs. Answer: Passenger on the back usually sit on your right hand side of your car. Plus the weight of your muffler which is located on your right hand side added weight to the spring.
Old Jan 19, 2002
GTekCiViC's Avatar
wow..... i learned sumthin new...... i always thought coils were just better because it's
a stiffer ride. Where springs bounce all around like a 6 4 lowrider hahhahaha....
Old Jan 20, 2002
ImmortalEX's Avatar
Super Member
ImmortalEX is an unknown quantity at this point
If you want a quality coilover, get a coilover with the threads on the shock itself. the sleaves will just give you problems down the road. IMO, that's what I would do. That's why I didnt buy GC's to begin with. Even though the "REAL" coilovers cost some $$, I think its worth it. That way you get new shocks & the coilover all in one. my $.02.
Old Jan 20, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
<< If you want a quality coilover, get a coilover with the threads on the shock itself. the sleaves will just give you problems down the road. IMO, that's what I would do. That's why I didnt buy GC's to begin with. Even though the "REAL" coilovers cost some $$, I think its worth it. That way you get new shocks & the coilover all in one. my $.02. >>
I agree. Get good quality the first time around. I learned the hard way.
Old Jan 20, 2002
blouisgod's Avatar
i was thinkin Tein coilover setups but they might be too much (around 1400). ayone know of any other brands coming out that are cheaper, besides APC
Old Jan 20, 2002
aznTrance's Avatar
aznTrance is an unknown quantity at this point
H&R is coming out with their full coilover set...
keep an eye out for those
they look pretty good
SoslowEj666
Mar 8, 2016 01:10 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
