shifting and braking
Old Mar 20, 2005
jpeg420's Avatar
jpeg420 is an unknown quantity at this point
today someone told me that instead of using my break when I come up on corners/turns, or slowing down at high speeds I should try down shifting and releasing the clutch to slow the car down.
does anyone hear do this? and what will it do to my clutch? I have been driving a 5 speed for about 2 months.
Old Mar 20, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
it will wear out the clutch (unless you match rev).... it's not necessary to do unless your brakes are gone or something along those lines.
Old Mar 20, 2005
Rennen's Avatar
New Mod on the Block
you have brakes for a reason. just use the brakes.
Old Mar 20, 2005
1PHATSI's Avatar
proudpinoy
1PHATSI is an unknown quantity at this point
yeah i step on the brakes down shift when i'm slowing down and turn.
Old Mar 20, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
There are many track techniques you could use... Notice I said track...
Old Mar 20, 2005
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
if u downshift instead of using the brakes u'll just end up burning out ur clutch faster...like the people above said, just use your brakes...
you shouldn't have to downshift unless ur going uphill or racing....usually during racing, u'd want to heal and toe
Old Mar 20, 2005
jpeg420's Avatar
i thought it was a bad idea thats why i decided to get more input on it before trying it, thanks.
Old Mar 20, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
theres nothing wrong with downshifting if you rev match. if you downshift with rev matching used in combination with brakes, it is perfectly fine.
Old Mar 20, 2005
Hawk's Avatar
You boost, I-VTEC
yea if your revmatching downshifting is fine coming to a stop or a corner. But whoever told you to slow down for a turn by down-shifting is a ***. Whats cheaper brake pads or a clutch?
Old Mar 20, 2005
1PHATSI's Avatar
proudpinoy
nobody did
Old Mar 21, 2005
Hawk's Avatar
You boost, I-VTEC
Originally Posted by 1PHATSI
nobody did
wasn't talkin to ya cheif, the thread starter said someone told HIM
its not about you doushe bag j/k
Old Mar 21, 2005
Al Gore FTW's Avatar
jdmtytedoridori
rev matching while downshifting should be ok, its what i do
Old Mar 21, 2005
MegaCivic2k1's Avatar
MegaCivic2k1 is an unknown quantity at this point
Rev match or Heel and Toe when coming to a stop or a turn, never just down shift and pop the clutch- you will wear it out. Here is a link for some lessons . Its from a BMW M5, but if you scroll down and click on the heel and toe theory and lesson videos, you will find some usefull info. Also check out the other videos for some great tips.
Old Mar 21, 2005
Zzyzx's Avatar
Autocross Junky
Your friend is talking about engine braking... and if you want to save the brakes a little, then you could do a bit of it for slowing down... and as long as you revmatch the down shift there will be little to no extra wear on the clutch. I tend to use it a bit when putting around the streets and don't need to stop quickly. As far as using engine braking for a turn... ABSOLUTLY NOT. as engine braking is essentially the same as applying the brakes to Only the front tires, you can cause some interesting handling issues on corner entry that way.
For racing... You should not engine brake either, for reasons noted above. if your on track your brakes are plenty strong enough to stop the car... if they arnt, then your running the wrong pads.
now there are other downshifting techniques for racing that have been mentioned by others above... but you dont need to use them on the street. (and none of them are designed to supliment the brakes)
Old Mar 21, 2005
S2000man01's Avatar
O RLY
which would you rather pay to replace? brake pads or your clutch?
i choose the brake pads. much cheaper to replace.
Old Mar 21, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Just make sure you have enough experience shifting (to where you can drive all the time without having to think about how to shift) before you start messing around with rev matching, etc.--you don't want to accidentally screw up your car.
Old Mar 21, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
whats rev matching? just making sure ur not downshifting to too high of rpms?
Old Mar 21, 2005
Zzyzx's Avatar
Autocross Junky
Heh... One sure fire way to destroy an engine is to down shift too soon.... (Rev-limiters only stop throttle on over-revs...)
Old Mar 21, 2005
rokenrolcivic's Avatar
rokenrolcivic has a spectacular aura aboutrokenrolcivic has a spectacular aura about
So you guys just throw her in neutral and use the brakes when coming up to a turn or stop? I've always downshifted, thats how I was taught, my parents drive the same and never had problems with worn out clutches. Isn't that why we have 5spds? In an auto the transmission automatically downshifts when slowing down so how can it be hard on the clutch or tranny on a manual? And if so is upshifting bad on a clutch too?
Am I missing something or doing something really wrong?
Old Mar 21, 2005
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
i use both, to gradually slow down (if i see a redlight in the distance), i'll just cruise and shift down at about 2000 rpm every gear except for first, i dont shift into first unless if I'm at or VERY near a stop. If I have to stop fast, I just brake.
If it's a slow and gradual shifts at somethinkg like 2000 or lower rpm, it's fine. But if you're downshifting at like 3500 then it'll wear a lot faster.
And to all those that say any downshifting will wear out the clutch faster, I downshifted in my '91 hatch with 204k miles on it, and so did my parents before I owned it, and neither of us ever put a clutch in the whole 204,000 miles, so I have confidence in it. It greatly depends on if you beat on your clutch or not.
Old Mar 21, 2005
HondCivc91's Avatar
heh no you're right. automatics downshit the same to gradually slow the car also. Next time all you guys are in an automatic car, notice how when braking, the car gradually shifts down. It's normal.
Old Mar 21, 2005
I thought so, Like said before as long as your not downshifting with the revs high how can it be bad? manuals are meant to be ****** be it shifting up or down! right!
Old Mar 21, 2005
S2000man01's Avatar
O RLY
you guys both said ****** instead of shifted. lol.
anyways, it's not really causing damage, just more wear and tear.
for example. let's say your average tranny lasts for 1 million shifts under normal use. if you downshift every gear as you slow down, look how many more shifts you are using.
in other words, it's just more wear and tear. IMO, you really shouldn't be using downshifting to slow down under normal conditions. it's unecessary and puts excess wear and tear on your clutch and tranny.
Old Mar 21, 2005
lol didnt notice that..
So I should just put in neutral and coast to a stop if possible?
Old Mar 21, 2005
HondCivc91's Avatar
lol downshit, lol .. good stuff.
it's up to personal preference. me personally, when I'm accelerating, I shift up. When I'm decelerating, I shift down. It makes sense to me, and as long as you do it gently it won't wear out the clutch tremendously. I always feel wierd just pushing the clutch in and letting the car brake to a stop while being in idle.
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
