Shell Gasoline....top tier
Old Mar 16, 2005
  #31
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
whoops its ethanol not methanol... my bad
i mostly use mobil becuase there is about 9 statons of them or hess since its the closest to me
Old Mar 16, 2005
  #32
joescivic02's Avatar
Abercrombie and Fitch
switching to premium every once in a while it bad acutally.... you stick to your octane rating and stick with it..... i use 87 and never had a prob......
Old Mar 16, 2005
  #33
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Shell is among one of the gas companies that I hate most. They're too expensive, and it seems like EVERYTIME I fill up with them I get less gas mileage than if I was to fill up with Exxon. Basically, Exxon/Chevron are the only places that I like to go...
Old Mar 16, 2005
  #34
-JB-'s Avatar
-JB- is an unknown quantity at this point
BP for me just cuz its convient. if i have a reason to switch ill go to exxon or shell which are kinda close but usually more expensive.
Old Mar 16, 2005
  #35
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
IMO, this is one of those discussions that has been around since the begining of gasoline, back where there was leaded gas, and than cars switched over to unleaded. Soon, almost all gas will have ethanol in it. I dont see any bad things about ethanol. My car gets better gas mileage when I use gas with ethanol, than without ethanol. In Iowa, gas that has ethanol is cheaper than gas without ethanol. I also believe it is added into it up here, cause it gets so muthafuc*in' cold up here, and the gas doesnt freeze. Bottom line, all gas have additives in it. Other bottom line is, 95% of us here drive 4-cylinder, 16,000 dollar, econoboxes called Honda Civics. We are not driving Bently's or Ferrari's here, where we have to put in higher octane gas into our cars unless you are bottle-fed or have a turbo. Look at it this way, why spend a couple more cents on gas to line the pockets of our good 'ol Pres.
[/end soapbox rant]
Old Mar 17, 2005
  #36
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
Originally Posted by bobsagator
Now playing Devil's Advocate, I remember reading numerous threads about how only morons pay for the 93 octane gas and our Civics were designed for the 87. So with the V-Power being 93, with all the extra detergents, should we now be using the 93, occasionally using the 93, or avoiding the 93 altogether since our cars are intended to have the cheap stuff?
If your intent is to have higher octane then it is the wrong reason to use a higher grade because the higher octane does not benefit a Civic in terms of performance. However, if you just want the extra detergent, then by all means. But it is more economical to put in a bottle of injector cleaner every 3K - 5K than to buy premium gas at every fillup.
meicalnissyen
Sep 25, 2015 12:12 AM
SidCivic
Sep 12, 2015 05:28 PM
tomas6791
Aug 22, 2015 12:20 PM
JLee93
Aug 21, 2015 05:44 PM
2005seTO
Aug 18, 2015 12:45 PM
