For s2000man and orion
Old Mar 10, 2005
  #31
S2000man01's Avatar
O RLY
Originally Posted by CivicsRdBest
bwahaha... This is amusing. I followed some of the equations and once again, I agree with the people that say that it won't matter much and the results will be similar to that on a straight flat.
Think about it, they're both being affected by the same gravity...
yes, but moving mass up/down an incline causes gravity to act as a vector, not a scalar.
Old Mar 10, 2005
  #32
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
will everything travel at the same speed in a vacuum
Old Mar 10, 2005
  #33
CivicsRdBest's Avatar
^^ I thought gravity always was a vector aimed downwards (or towards the center of whatever planet/heavenly body you're on).
Anyway, what I meant was, if both objects were moving on the same incline in the same direction, the effect of gravity would be the same on both objects. I do understand that it will affect it slightly as it slows an object down while moving upwards or while increases the velocity of an object while moving downwards.
Old Mar 10, 2005
  #34
y.e.c.r.'s Avatar
y.e.c.r. is an unknown quantity at this point
Damnit listen to what I said!
Old Mar 10, 2005
  #35
S2000man01's Avatar
O RLY
yes, the effect of g will be the same, but the effect of G will not. since the object is moving up as well as forward, the new force comes into play, and that force is gravity as a vector involving acceleration. i wont re-post the equation, since i've already posted it once in this thread.
you are confusing newton's 2nd law of gravity with the 3rd law of gravity.
Old Mar 10, 2005
  #36
NoFriends's Avatar
I like ruining your threads.
Stfu, some people are trying to carry on an intelligent conversation. If you dont want to read it, then go elsewhere.
Old Mar 11, 2005
  #37
Jrfish007's Avatar
Originally Posted by gsrchad
first off. this is again nonsense, since both vehicles are rwd, and when on a hill will gain traction. since traction wasnt an issue before it isnt now...
and the solutions were for 2 rwd cars.... so that was enough stating...
should i write this out on my engr paper professor?
You can write on what ever paper you want, you're still wrong.
So what you are saying is that a Trans Am and an s2000 suspension will load the same. I'm not sure what type of TA he was racing, but if it had a V8, you have traction problems all the way through 3rd and even shifting in to 4th, not sure what year it was or if it was a WS-6 or not though (so I can not believe traction was not a problem). Anyway, if the TA has more power it can, say it has 20% more traction, that's 20% more power it can put down all the way up the hill. While the S2000 has the same conditions, it doesn't have the torque to take advantage of it anyway, even though it's frame is far superior hence it won't have the body twist from torque. In this paragraph I have mentioned 3 different things you completely left out.
Listen, I'm not going to spend time on you (mainly because I am way to busy to go look into an applied physical book and pull the proper equations out, and still only have a simplified version of the story). Secondly, nobody here agrees with you, I'm not the only engineer on here that said you can't use that simple of an equation to model anything other than your imaginary simple physics land that you seem to think we live in. If you think you can model something using your oversimplified equations, go for it. And when you get a real job, let me know how that goes for you.
BTW, your professor probably told you that because he didn't want to go over your head in explaining a more complex situation you don't understand. You obviously have no idea how complex modeling something is.
S2000man01... lock this thread, I'm tired of this guy who everybody says he's wrong (or over simplified) and he still won't listen.
Old Mar 11, 2005
  #38
orion_squall's Avatar
hi there
Hi there,
I am not sure if you are with S2000man and me or not, but I feel that you are.
YES, When we do physics we have to first understand the basic concepts I have shown before; about force, acceleration, freebody diagram, vector quantity, scarlar quantity and energy conservation.
S2000man seems to understand these concepts because he spent time to go over my clearly stated equations and modellings. I am impressed and glad.
Old Mar 11, 2005
  #39
Jrfish007's Avatar
Originally Posted by orion_squall
Hi there,
Well, I'm mostly with you guys. S2000man01 has a much more complete understanding of the system and understands that these equations are only partial. Although I think he is leaving out some stuff, I think he has most of the key concepts down. I am not an applied physics person, so with out researching, I can not say specifically what is wrong and what is writing and frankly this is not important enough for me to spend that kind of time on. But I know that this situation is far more complex than most people realize, for one to do it properly will require something like finite element method to estimate all acting force distributions, and of course this can not be done on paper, but most be done with a computer as it will probably produce well over 50,000 points, depending on how accurate you want to be.
I’m wrong to say the other gsrchad is wrong, sorry to gsrchad, you have applied what you’ve learned, good job for that. But he must realize that things like this are not as simple as he thinks. Just because you can scribble some equations on paper doesn’t mean you know all the forces at work. I too had this concept when I was an undergrad in my sophomore year, but I quickly humbled when I went to an applied physics seminar and saw just how much really goes into this stuff. All the equation on here would be laughed at by anyone with a slight knowledge of applied physics, these guys deal with equations that are three lines long and take over 10 pages to solve just to explain how a rubber ball bounces off a wall.
Old Mar 11, 2005
  #40
Jrfish007's Avatar
Hi there,
Just out of curiousity though, are equations and models posted?
Old Mar 11, 2005
  #41
S2000man01's Avatar
O RLY
a LOT of equations have been posted.
Old Mar 11, 2005
  #42
Jrfish007's Avatar
Yeah, but I wanted to know if it was all in one post or anything like that, I crunch for time over the next few day and didn't want to scan an entire thread for my curiousity. I will glance through the previous thread and see if I can follow later today.
Old Mar 11, 2005
  #43
S2000man01's Avatar
O RLY
this thread has the majority of calculations.
Old Mar 11, 2005
  #44
gsrchad's Avatar
gsrchad is an unknown quantity at this point
i didnt even read this whole post... becasue there is no need to...
my point is the suspension in these cars make absoulty no difference to our origianl arguement.... NONE what so ever...
Old Mar 11, 2005
  #45
gsrchad's Avatar
if you could actually read, you would understand that about 90% of the people that agree with you, are not talking about the actual problem at hang..
you would see that everyone things we are talking about if you add weight to a car up a hill its going to travel slower...
that if stateing the obvious. So yes, lots of poeple seem to agree with you becuase they think thats what your trying to prove...
but its not....
Old Mar 11, 2005
  #46
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
If you have a fat chick in the car will it scrape? Will it scrape more if you go over a speed bump while climbing a hill?!?!?!?!?!?
Old Mar 11, 2005
  #47
Jrfish007's Avatar
The last thread was closed because they were incorrect and didnt want to ramble on any more my sister did this and brother did that and thast what happened...
here are some actual numbers to prove that it doenst matter if its a hill or a flat surface.. if car A wins hill, it will win FLAT....
first thing first...
KE = 1/2*m*v2,
where m is the mass and v is the velocity
with this in mind... at the end of the race... we will calculate the experimental data... that energy found in the cars kenetic energy CAN NOT be greater OR LESS than the kenetic energy and potential energy at the hill race....
with that being said... lets start
you claim to win flat race.... by 1 car.. so lets say thats about 5mph faster than your buddies camaro...or trans am, whatever it is..
s2000=1255kg say finished at 100mph= 44.7 meters/second
trans am=1551kg and finished behind the s2000 say at 95mph=42.5m/s
at the end of the race, the engine in the honda put (.5)(1255kg)(44.7)=28049joules of energy....
the trans am put in (.5)(1551)(42.5)=32958 joules
Dude, give it up. Look above, you even miscalculated you rnumber!!! You say Ke=.5 m v^2, then you give this equation: (.5)(1255kg)(44.7)=28049joules. Lets take a look at this, 1. you forgot to square the velocity term and 2. thats not the force term, remember the Ke needs a mass term in terms of force, not wieght terms. Look I didn't even get past you first calculation without finding 2 MAJOR errors, you want me to believe the rest of it?
Old Mar 11, 2005
  #48
GuliziaN's Avatar
Powered by Honda...
GuliziaN will become famous soon enoughGuliziaN will become famous soon enough
Originally Posted by xavier
gsrchads first post is like reading latin for me but it sounds like he knows what he is talking about. I think the point is irrelevant and useless to prove but...sounds good to me
Haha... Good I'm not the only one.
Old Mar 11, 2005
  #49
Yeah,
That is what I felt too. He never understood "force" at the first place. The way he state equtions made me doubt if he had any physics basis at all.
Anywyas, I have already stated the real energy method as well. If someone find any mistake on it, please let me know. Or if you have a question, let me know as well. But don't come to me with "AWD", "RWD", "spring rate" excuses because if one can't understand my method then one can never go futher talking about the rest. So understand the basics first then we can go on with the rest.
Old Mar 13, 2005
  #50
gsrchad's Avatar
if you would notice the time of psoting... its was i believe at 6am... and didnt go to bed yet. so SORRY for not double checking my numbers...
but the error cancels each other out since i did it twice... so you point is valid, but pointless since my point i was trying to get across didnt change from it
Old Mar 14, 2005
  #51
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
no, when you forget to square something, it does NOT cancel out, unless it's the same number, which it wasn't.
wow, math in america is dead.
Old May 6, 2005
  #52
gsrchad's Avatar
i amde it for both arguements, which makes my point still stand... sinec i was comparing the numbers for 2 things, and i did it to both, they still have comparison to each other...
Old May 6, 2005
  #53
Rennen's Avatar
New Mod on the Block
we are all forgetting 1 very important factor... the factor of no one cares about this.
Old May 6, 2005
  #54
S2000man01's Avatar
O RLY
old topic
k20em2504
Dec 13, 2007 11:11 AM
btuner
96
Mar 14, 2005 09:23 AM
spunger
Nov 9, 2004 01:42 AM
2K2SilverCivicSiR
Jun 5, 2003 11:45 PM
GoCivicRacerGo
Dec 13, 2002 08:30 PM
