A new way to check vtec engaging???
Old Jan 26, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Nothing for you newbs!
Old Jan 26, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
the power range in a stock D17 motor begins at around 4000.... so... thats why. now... youre afraid to slip and youre doing this? For a lot of us, it's icey out there.... so, folks use some common sense and logic before doing anything like this on icey/snowy surface.
Old Jan 26, 2005
S2000man01's Avatar
O RLY
according to honda, vtec on the D17A2 engages at about 4300rpm
Old Jan 26, 2005
im stock now! T.T
I said "im not afraid". of course i did this only when no one was around. it would be stupid if a person did this on snow. I never said do it on snow, only on slippery roads. and I felt it skid on 4500-rredline. it doesnt spin any lower than 4500
Old Jan 26, 2005
Caucasian.Asian's Avatar
someone is going to do this, crash into someone, get hurt or die, and sue the **** out of you. at least thats how californians do it....
Old Jan 26, 2005
im stock now! T.T
lol, I know, people aere stupid. There is always one person that needs to do it. And those are the stupid ones I'd like to see do it and get into trouble.
Old Jan 26, 2005
im stock now! T.T
I hope it wont be you.
Old Jan 26, 2005
i was thinking about it, but sadly, i have to vtec.
give me reps for saving your ***!
Old Jan 26, 2005
R3DL1N3's Avatar
mine engages at 3k every time
Old Jan 26, 2005
im stock now! T.T
how about giving me points. You have alot yourself. I only want 3k to make a sticky
Old Jan 26, 2005
PunkingCivic's Avatar
I need TP for my bunghole
Get the Du-luck vtec indicator light.
It is a tad pricey but looks good!
Old Jan 26, 2005
wonderz's Avatar
wonderz is on a distinguished road
how do you wire ^that^?
'cause the regular method of tapping into the ecu wire is not accurate, right?
Old Jan 26, 2005
see this near my info? -------->
click that and give me a positive rep. no points are involved.
i'm glad i saved this forum on word before you changed it.
Old Jan 26, 2005
im stock now! T.T
ok, I did it. you did save my *** from getting sued. there are plenty of morons out there.
Old Jan 26, 2005
Titleist71's Avatar
ive seen the vtec gauges...lol.
Old Jan 26, 2005
thank you, i knew you would submit. lol j/k
Old Jan 26, 2005
im stock now! T.T
so your reputation will be better? who needs it.
Old Jan 26, 2005
im stock now! T.T
rather invest in an a/f ratior gauge than that. vtec gauges are totally useless.
Old Jan 26, 2005
exturbo6's Avatar
does anyone have this vtec indicator?
Old Jan 26, 2005
not that I know of
Old Jan 26, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
i have on installed on my car and was very suprised to see that the vtec is kicking in around 2500 rpms, in and gear. i thought it would have been the 4000rpms like you guys are saying, but its def at 2500, every time
Old Jan 26, 2005
S2000man01's Avatar
O RLY
I know that if i were to negative rep you, you'd drop to 2 red bars and lose about 9000 points.
Old Jan 26, 2005
S2000man01's Avatar
O RLY
you have your vtec gauge hooked up incorrectly.
on a D17 according to the electrical schematics honda manual, vtec engages the hi cam profile for the intake valves at 4200rpm.
Old Jan 26, 2005
wonderz's Avatar
how do you hook up vtec gauge correctly?
Old Jan 26, 2005
flotsamm's Avatar
4200 rpms sounds high. Where in the manual did you read that? I have the Helms manual and would like to read up on that. I always thought is VTEC kicekd in at ~2800 or so depending on oil pressure.
Old Jan 26, 2005
S2000man01's Avatar
O RLY
take a look at a dyno from a stock D17
notice the spike in torque right around the 4200-4300 area?
that's your hi cam vtec kicking in. 2800 is WAY off.
Most hondas have a set vtec engagement point for their high cam profile, including the D17. And in general the hi cam kicks in somewhere near the upper 2/3 of the rpm range. 2800 would kill performance since you are hitting a hi cam profile not made for such a low rpm.
But take the F23 engine for example, vtec engagement on this engine is variable depending upon load.
Old Jan 26, 2005
hotrodcivic2004's Avatar
my civic has no boost
i think VTEC should be engaged all the time
Old Jan 26, 2005
S2000man01's Avatar
O RLY
actually technically vtec IS engaged all the time.
vtec is a combination of using 2 different cam profiles for 2 different rpm ranges and combining them over the rpm range. it uses a low cam profile better for power at lower rpm, then switches over to a more agressive cam profile with higher lift/duration on the higher end of the rpm range.
so really vtec is always engaged. when someone refers to vtec "kicking in" what is happening is that hi cam profile being enagaged.
the reason THAT cannot be on all the time is that using a profile with such an agressive lift/duration during lower rpm would actually HARM performance and cause the engine to have a very rough idle or even stall.
Old Jan 26, 2005
CivicsRdBest's Avatar
^ Not only that, but you wouldn't notice the kick everyone enjoys when it engages because it would just be one profile.
Old Jan 26, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
i thought vtec engaged at 5,5, what do they engage on on the 6thgen and rsx type s? is ours different then 6thgens? my friends 6thgen would make a distinct sound at 5,5 where vtec engaged? i dunno
