Taking yur car to get tuned on a dyno
Maybe. Remember tho you need something to tune with like the vafcII. That would be the best. However as far as being worth it, it always helps to have the correct a/f ratio. I gained 2whp after dyno tuning. They add or remove fuel to make the curve a straight line. As far as being worth it, $300 for vafcII and $125 for dynotune = $425 for 2whp. Is it worth it?
Now auto is a whole other story. My modded auto only makes 100whp. So it's still slower than a stock manual. I think the whp between ex and lx manual is only 5-10whp. Not very much.
Originally Posted by ncirom2003
really ... i thought it was 20% loss in fwd cars that would be like 91... ill go with 90whp...
what about tourqe?
what about tourqe?
End Bringer
dyno tuning is not worth it unless you are tuning your car after a big modification on the car, usually new bigger turbos or turbo on a n/a car. the purpose of tuning is to modify the fuel supply map in various rpm to get a better a/f ratio and also allow tuning of ignition timing, boost pressure and other engine related items, provided that you have the modification to do so (stand alone ecm, vafc, etc...)
i am going to a dyno this weekend to see my dyno numbers, since it's 30 bucks for 2 pulls, but i am not going to dyno tune it until i get a standalone ecm (www.mrcontrols.com)
if you only have bolt ons such has intake, exhaust and header, those modifications do not make enough of an air/fuel variance (if at all) to justify the cost of dyno tuning
ashleymmackey
Apr 18, 2015 09:48 PM
chgofirefighter
Apr 18, 2015 08:08 PM
