Oil Types Meaning
Old Dec 31, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Oil Types Meaning
so theres oils out there, 5w20, 10w30.. blah blah blah
whats the 5w and 20 mean on the lable? what do the numbers mean
Old Dec 31, 2004
98oRange's Avatar
98oRange is an unknown quantity at this point
Viscosity or thickness
there are 2 types of oil.
we use multigrade in our cars.
the first few numbers are viscosity.
5 10 and 15 are good examples.
the lower the number the thinner or less resistant they are
the "w" means winter conditions it keeps its viscosity at lower operating temperatures
the higher the second number the warmer the weather.
I use 15w-50
I live in florida
its thick and wont work to well in temperatures below 0
hope that is clearer....
Old Dec 31, 2004
KalliGarri's Avatar
yeah it helped, thanks!
Old Dec 31, 2004
98oRange's Avatar
No problem.
Old Dec 31, 2004
Keet's Avatar
Keet will become famous soon enough
Good post, short thread!
Old Dec 31, 2004
solar's Avatar
solar is an unknown quantity at this point
I use 15w-50
I live in florida
You live in Florida and you use 15w-50? I also live in Florida and all I've ever used in my vehciles is straight 30 weight, except for my EP3 which I use 5w-20, and I've never had any problems in over 20 years of driving.
A 15w-XX means that oil will hold a viscosity of a 15 weight oil at a cold start up in a cold climate until its warmed up. So the higher the second number doesn't nessarsarly mean higher tempurature. While a 50 weight oil can be used in Florida, I would never run that high of a oil. The main reason is a higher weight oil at start up is very "thick" and may have problems properly flowing throughout the engine, and it could cause premature wear. I have used straight 50 weight oil in some of our old tow trucks, but those engines have over 200,000 miles on them and are pretty "loose"
While this whole subject can be debated to no end, the main thing to realize is that most all oils made now offer more than enough protection under most driving conditions. Plus if you change your oil regularly with any weight oil, you shouldn't have any problems with oil related failure.
Old Dec 31, 2004
Maurizio's Avatar
Maurizio is an unknown quantity at this point
That's right. The first number is the relative viscosity at lower tempuratures, the second, the viscosity at higher tempuratures.
5w20 means the oil acts like a 5 weight when cold, and a 20 weight when hot.
Old Dec 31, 2004
98oRange's Avatar
it rarely goes below 40 here.
Old Dec 31, 2004
98oRange's Avatar
i use 15w50 because my car burns off anything lighter and I am not worried about sub-freezing conditions. not like when I lived in michigan.
Old Jan 1, 2005
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
something is very wrong with your car then.
Old Jan 1, 2005
98oRange's Avatar
xtreme heat conditions. thats whats wrong with my car.
Old Jan 1, 2005
ctx66's Avatar
no way. its just your car. im sure theres plenty of civics in florida running 5w-20 or even 5w-30 without any problems.
Old Jan 4, 2005
solar's Avatar
Yup, me Look at my earlier post, I run straight 30w oil in both my Mustang and Van and 5w-20 in my EP3. I live in the Tampa area, and it gets very hot here in Florida, but 5w-20 oil isn't going to break down under Florida conditions. Plus my van has over 200,000 miles and my Mustang has 135,000 miles, and neither of them use or burn oil.
Old Jan 4, 2005
Civicious's Avatar
Civicious is an unknown quantity at this point
I run 0W/ 20 in hot azz AZ with no problem. I only used 50 rating in my 74 Camaro when it was burning oil!
The 0W/20 is what my Honda dealership recommends.
Old Jan 4, 2005
Grumble's Avatar
Stop f*cking with me.
Grumble is an unknown quantity at this point
I run the recommended grade. However, it frequently snows and goes well below freezing here. Should I use another grade of oil??
Old Jan 4, 2005
98oRange's Avatar
nah. recommended is fine.
Old Jan 4, 2005
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
I use 5w20 in houston... it gets really hot and I've had no problems
Old Jan 4, 2005
KalliGarri's Avatar
me to, but will soon use mobile 1 synthetic 5w30 (TURBO)
jessica19699
24
Jul 21, 2017 06:59 PM
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
The Big Dutch
Jun 9, 2015 07:49 PM
