What Synthetic Engine Oil Do You Use?
Old Dec 30, 2004
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Just wondering what everyone uses on his/her vtec or non-vtec.
Old Dec 30, 2004
streetglower's Avatar
mobil 1 10w-30
Old Dec 30, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
penzoil 5w 50 syn, non vtec
Old Dec 30, 2004
what the hell, why 5w-50?
Old Dec 30, 2004
Drakkar's Avatar
Drakkar is an unknown quantity at this point
10w- 30 any brand really
honda engines seem to prefer thin oil
my s2000 ask for 5w-30 which i found strange
Old Dec 30, 2004
xam's Avatar
xam
cause i want 2
Old Dec 30, 2004
im stock now! T.T
HMMMM!?!?!?!?!?
Im hoping all of you are using that oil once?
Your manuals say you should use 5w 20 if the oil is synthetic.
Old Dec 30, 2004
jttegx's Avatar
OMNES AD UNUM
5w-50? jesus christ
<--- 5w-30 mobil 1
Old Dec 30, 2004
im stock now! T.T
change to 5w 20
Old Dec 30, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
^^^ besides the manual saying so, (although thats a good reason to use 5W20).... other oils can be used. If youre in LA, where it doesnt really get cold, 5W30 or even 10W30 is fine.
Old Dec 30, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Originally Posted by Civic_RedLine
change to 5w 20
The Honda technician I talked to before I made my first oil change told me that they use 5w 30 even though the manual says 5w 20 when they put in full synthetic here because it's so hot and it only gets below freezing for three or four days out of the year. So I use Mobil 1 5w 30 in my EX.
Old Dec 31, 2004
ragingSPAM's Avatar
I just burnt my tongue
AMSOIL 0W-30 SAE full synthetic...35,000 miles with no oil change...mmmhhmmmm...its good ish...noticed incredible gas milage increase and power in the lx...its awesome oil
Old Dec 31, 2004
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
mobil 1 5w20
Old Dec 31, 2004
hotrodcivic2004's Avatar
my civic has no boost
i'm a castrol gtx 5w-30 man all the way. wont use anything else.
Old Dec 31, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
castrol mobil 1 5w-20
Old Dec 31, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
Mobil 1 5W-30 all the way...
Old Dec 31, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
mobil 5w 30
Old Dec 31, 2004
pon55's Avatar
<either or>
Castrol Syntec 5-20
Old Dec 31, 2004
jackal903's Avatar
jackal903 is an unknown quantity at this point
mobil 1 0w-20
Old Dec 31, 2004
EM2Civic's Avatar
EM2Civic is an unknown quantity at this point
35000 miles with no oil change????WTF???
Old Dec 31, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
Mobil 1 5w30
Old Dec 31, 2004
HMMMM!?!?!?!?!?
I started with 5w-20/0w-20, but now since I have about 81k on my car, I use 10w-30.
Old Dec 31, 2004
98oRange's Avatar
98oRange is an unknown quantity at this point
I use Mobil one 15w50
dosent burn off.
Old Jan 14, 2005
BoOsTaNiGgAh's Avatar
BoOsTaNiGgAh is an unknown quantity at this point
is it tru that if u put synthetic in your engine, you can never go back to normal oil?
Old Jan 14, 2005
exturbo6's Avatar
i know this topic has been cover plenty of time i believe but what really is the best for our engines. especial turbod cars? 5w - 20???
Old Jan 14, 2005
_Viper_'s Avatar
I USE VEGETABLE OIL (Crisco to be exact) Runs like a top..
My car does smell like French fries Though...
Old Jan 14, 2005
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
owners manual says 5w 20
Old Jan 14, 2005
Pharoh's Avatar
Bobaganoosh!
Mobil 1 5w30
Old Jan 14, 2005
exturbo6's Avatar
Old Jan 14, 2005
Jrfish007's Avatar
A turboed car should always be using a top end full synthetic oil. Reasons:
1. A turbo produces lots of heat, and the oil sokes the heat up
2. Oil breaks down when heat is exposed to it, sythetic oil last longer than organic oil when exposed to heat
Conitinue to use 5w-20,
1. 5w-20 is light and our engines are NOT designed to use a heavier oil (particually the piston rings) USing a heavier oil will not allow the oil to penatrate into all the ring section, this means your ring will not get the proper luberaction and you will have metal rings rubbing on metal cylinder walls, now this is not a fast process as only small fraction of the rings get exposed, but you WILL cause premature ware on the internals of you engine. Not to mention that if you go to thick, the pump won't pump the oil and then you won't have oil on the top end of you engine, hence a you will devlope a blown head gasket (I know all this from experience)
2. Using a heavier oil will also rob you of power. In the engine oil pan, the crank hit your oil and splashes it up on to the cylinder walls (no civic's don't have a dry sump oil injection system or any fancy stuff). This means the crank has to go through the oil, you can relate this to waving your hand in air and then putting it in water and doing the same thing, it will be harder to move your hand in the water, right? Now put your hand in the crisco do move it around, it's going to be really hard right? Well the thick the oil becomes, the hard the crank has to push to go through the oil, hence the less power that get to you tires and the worse MPG you get. I know that 5w-20 and 10w-30 don't seem to make a big difference, but remeber 1. that your crank is hitting this oil at 2,000-7,000 time a second and 2. that the properties of oil change the harder you hit it (it called historiesis).
So how come people didn't just use 5w-20 to start with back in the '50 and '60's? the same reason we don't use a 0w-10 now. If you use to light of an oil, it will seep past the ring and into the combution chamber. This really isn't to bad for you engine, but you catalytic converter and oxygen sensors won't like, not to mention you won't pass any type of emmisions check. The type of oil you use is directly related to the tolerances with in the the engine.
