the term "stock"
Old Dec 27, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
the term "stock"
after reading few arguments and whatnot on the board here, i came upon a certain term and wanted to know what are ppls opinions and the true meaning of what "stock" in automotive terms really mean?
im no professional racer in any catergory, im just your average car enthusiast. but what i think the term stock means is that the car cannot have any aftermarket part that will affect the cars performance at all.
someone on the board here defined the term "stock" different which i thought was interesting. he basically says the toggling following wouldnt be considered stock:
-lowering tire pressure
-removal of muffler, b-pipe, pretty much any exhaust component?
-gutting for weight reduction
-removal of power equipment (power steering, power doorlocks, etc)
so i want to know what are your guys input, opinions, offical terms of what the word "stock" stands for in automotive terms? and why?
Old Dec 27, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
stock = came from the factory that way... not modified
Old Dec 27, 2004
johnbt23's Avatar
yeah!!! what half and half said.........lol
Old Dec 27, 2004
Wolfgang5884's Avatar
yeah i think stock means no mods what so ever
Old Dec 27, 2004
Got Boost???'s Avatar
Corvette owners are the worst. Anything short of a twin turbo kit is considered stock. Many see I/H/E, thermometer, and drag slicks as still being stock.
Typical Corvette owner : "I ran a 10.38 stock"
Old Dec 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I agree.
Old Dec 27, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
not modified, not touched, everything OE.....(maybe with the exception of motor oil, tranny fluid coolant, etc).... thats stock.... I think thats what most ppl in the world perceive it as.
Old Dec 27, 2004
kirks04ex's Avatar
word
Old Dec 27, 2004
88AccordDX's Avatar
Freedom costs a Buck o'Five
88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute
And every other Corvette owner is not impressed... haha
Old Dec 27, 2004
S2000man01's Avatar
O RLY
lowering tire pressure is STILL considered stock. it's something everyone can do on the fly and doesn't modify the car, nor affect it's hp.
removing exhaust components generally can't be done on the fly, is modifying the car AND modifying the HP, so that's not stock.
same for removing power equipment.
gutting car for weight reduction is a gray area. if it's basic things that can be done in minutes, and quickly re-done, it's still considered stock for the most part. but if you're talking major weight modification, then that's not stock. but taking out your spare would be stock. removing a passenger seat or back seat is in the gray area.
Old Dec 27, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
To me stock means OEM......nothing done to the car.
Old Dec 27, 2004
Arith's Avatar
Arith has a little shameless behaviour in the past
Exclamation
exactly.
Old Dec 27, 2004
S2000man01's Avatar
O RLY
with the exception of tire pressure. that is a generally accepted rule at the track. period.
Old Dec 27, 2004
D17thgen's Avatar
lets say u walk out the dealer lot with ur brand new civic. after 2500 miles, u switch over to a better motor oil. say mobil 1 0w-20. you filled it with the correct amount and no problem with the procedure. next day, a problem occurs and your engine felt "boggy". (could've been a recall, lack of ownership, some mysterious). honda works on your car and when their done, they tell you "your engine warranty is no longer for service because you used a non-honda motor oil fluid on your honda automobile"
how would you guys react?
my point is that every brand new honda car that comes off the dealers lot is definately carrying the honda motor oil. by changing this, is it no longer "stock"?(exclude the used cars)
Old Dec 27, 2004
S2000man01's Avatar
O RLY
changing motor oil is still considered stock. changing motor oil on an otherwise stock car, simply won't improve your performance, no matter what your fast and furious friends tell you.
also, honda CANNOT void your factory warranty because you use non-honda motor oil. i dont know if you were saying "what if", but just so you know, it would be illegal for them to void your warranty because of non-honda motor oil.
Old Dec 27, 2004
SIinthesky's Avatar
I don't think maintence counts. (I.E. brakes, oil, coolant, etc.)
Old Dec 27, 2004
CivicsRdBest's Avatar
To some stock means no power-adders, but I'm with most people here, OEM means stock, nothing more, nothing less... If it was not manufactered for the country that's it is for, like JDM stuff than it is not stock...
Old Dec 27, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
well stock can be having a stock k20a motor on the civic but yeah most of the times it means unchanged from factory
Old Dec 27, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
the question is what is stock, not does motor oil void your warranty.
Stock is stock after market hubcaps are not stock, aftermarket intake is not stock, if you wear out your stock tires, and replace them with the same size you car is stock.
If you put 90 Wt. Oil in your engine, or fill the radiator with Oil or something that would probably void your warranty.
Old Dec 27, 2004
mexinaction's Avatar
when i hear stock i usually refer to it as being the way it came from factory, mostly performance parts or suspenion mods
you can have ICE, but other than that i wouldn't consider it stock if it had anoy other mods
Old Dec 27, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
well if u go into drag racing, then stock means u cant use any part that did not originally come on that make/model car. model doesnt matter, so like i could put an EX engine into my LX and it will still be considered stock.
Old Dec 27, 2004
vietstylez's Avatar
i have i/h/e but i consider it stock.. when ppl ask me "u have anything done to your motor?" i just say no.. cause i dont really consider i/h/e real mods, especially for our car.
Old Dec 27, 2004
armjr2's Avatar
armjr2 is an unknown quantity at this point
I consider stock the way it came from the factory or OEM stuff, but everyone thinks about the meaning of stock in different ways
Old Dec 27, 2004
ajhdragon's Avatar
7thgens official a$$hole
stock is exactly how it came out of the factory.
Old Dec 27, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Stock is a car with:
-any air cleaner that fits in the stock airbox,
-any brake pad compound that fits in the stock caliper and can be used with the stock rotor
-with any front anti-roll bar
-any cat-back exhaust
-using any DOT approved tire that fits on a factory sized rim
-is otherwise unmodified
.... according to the SCCA.
Old Dec 27, 2004
ajhdragon's Avatar
that sounds good, really all the stuff you listed is just basic maintnence.
Old Dec 27, 2004
diskreet's Avatar
you can just stop there. thats enough info.
Old Dec 27, 2004
Yup. Basic maintenance doesn't count. Then again, alot of aftermarket parts are technically considered oem replacements since the function is retained. What about putting oem parts from honda on your car? I think any mod that changes the exact image of the car when you first got it from the factory will mean it's modded.
Old Dec 28, 2004
D17thgen's Avatar
does the honda FP (factory performance) package counts as stock? i believe its just suspension work?
if tuning the suspension makes the car not stock, so if honda (the orginal manufactuer) creates parts that "enhance" your car, then is it stock?
lets say honda and aem collided* and join companies/corporations. honda advertises the aem v2 on their showcase at the dealer performance shop and it will not void warranty if bought & installed by honda themselves. would u consider that stock still?
Old Dec 28, 2004
S2000man01's Avatar
O RLY
if those intakes were offered standard on a particular trim, rather than something you buy and honda puts on, even though it's a "honda" part, then that is no longer stock.
it would have to be something offered at the trim level nationwide as a standard.
