I have a ?
Old Dec 3, 2004
  #31
cdmx's Avatar
Originally Posted by Down_
Honda Design'd there engines to be drivable at a cold start.....meaning you dont have to wait for them to warm up........its in the manual.........and its perfectly safe in ALL cars regardless of model to go over 3K ....if it wasnt ...your red like wouldnt be at 5K or whatever its at........a redline is in place to tell you were your engine parts cant take the centripical/presser/ or other force's exerted on the engine....
Originally Posted by JP375
Not very accurate in this context. You do not want to push your engine until it has reached normal operating temperature. It has less to do with engine design and more to do with oil viscocity. When the oil is cold it does not flow as easily as when it is warm. This means the oil may not be seeping into those tight spaces "as well". It will be adequately lubricated ,but not to the point where you want to mash the gas when you just started your car from -10 deg F. Also, a redline has little meaning outside of a single moment in time. The redline somewhat indicates the max your engine can handle in the form of stresses etc, but this does not mean you can cruise around at redline all day and suffer no ill effects. Time is a very important factor when considering RPMs and engine wear. This is when factors such as creep come into play, and thus causing parts to fail. As an added tidbit, I believe BMW M3's electronically limit your revs when the engine is cold so that you do not cause any damage. Kinda cool. As for the civic, again, if you have good oil and your not cruising around town at 5k, then push her. She likes it when you play rough....
What are you talking about he said "driveable" That sounds accurate to me, even the honda manual Clearly states in cold conditions to drive the car like normal to warm it up. I dont think he said anything about pushing the engine
Old Dec 3, 2004
  #32
cdmx's Avatar
Im in a bad mood...
Old Dec 3, 2004
  #33
S2000man01's Avatar
O RLY
i agree with cdmx. he said it's driveable from a cold start, which is perfectly true. in fact, most hondas usually won't engage the hi-cam profile on vtec until the engine is warmed up.
if i mash the gas on my car after a cold start, a 6000rpm rev limiter cuts in on the fun.
Old Dec 3, 2004
  #34
JP375's Avatar
JP375 is an unknown quantity at this point
Originally Posted by cdmx
Im in a bad mood...
Yes. Yes you are....but you are correct, I did not address his quote all that great. Here's the thing though....name me one car that is not "drivable" when its cold? It just seemed like an odd thing to say regarding cold engines. I was spitting thoughts out from other posts as well. Shouldn't have quoted him specifically. My bad. As for you....turn that frown upside down.
Old Dec 3, 2004
  #35
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
true, their has been one or two times when i was late for work and it was cold as hell outside and i only gave the car about a minute to warm up and when i got to about 3k it felt different like it was lacking power. But lately since its been really frickin super cold i will let my car warm up for about 3-4 mins but still wait to mash until its really warmed up. I know some of you guys lives where it snows but even where i'm at its like 25 degrees at 6am
Old Dec 4, 2004
  #36
allmotor's Avatar
nor cal 7thgens
**** i have beaten my mtr up and no problems.
Old Dec 4, 2004
  #37
ThaitaniumGK's Avatar
..w0rrrrrrd..
ThaitaniumGK is a jewel in the roughThaitaniumGK is a jewel in the roughThaitaniumGK is a jewel in the roughThaitaniumGK is a jewel in the rough
I've been driving 5-6k rpms on a daily basis.... in fear of blowing up my engine.. i'm gonna try to keep it around 3-4k.... does anybdy know if i redline it that i will blow up my engine?
Old Dec 4, 2004
  #38
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Manufacturers normally set the redlines lower than the engine's actual breaking point in order to prevent you from popping your engine. You also have a rev limiter and fuel cut to baby sit you if you can't understand the point of redline. Of course hard running is harder on the engine, but it certainly isn't going to pop it right away....occasional jaunts are fine....just don't treat your car like a 2 buck ***** and you're good.
Old Dec 4, 2004
  #39
zachgeyer's Avatar
honda sux no madder what in fornt of the X
Old Dec 4, 2004
  #40
S2000man01's Avatar
O RLY
wtf are you talking about?
Old Dec 4, 2004
  #41
RESIDENT ROTOR HEAD
Yeah that makes absolutely no freakin sense at all...
Old Dec 4, 2004
  #42
hawkz99's Avatar
hawkz99 is an unknown quantity at this point
I think he meant something like LX or DX.
Old Dec 4, 2004
  #43
jiggerachi's Avatar
Zoom zoom
jiggerachi will become famous soon enough
Only reason to keep it around 3-4k is for gas mileage, just be smart about it & change your oil.
Old Dec 4, 2004
  #44
ADS's Avatar
ADS
ADS is an unknown quantity at this point
What is a good oil filter combo to use a little off topic but kinda is on topic......ya man ur motor wont pop for a while i have 1992 civic with 386,000km on it orginal motore and clutch....and a 2003 unfortunately orginal motor..
Old Dec 4, 2004
  #45
2k3kansasEX's Avatar
Got the broccoli in my back pocket
2k3kansasEX is an unknown quantity at this point
it is a honda
Old Dec 4, 2004
  #46
Wolfgang5884's Avatar
I usually **** around 3500 and I take it up to 7 grand about twice a day
Old Dec 4, 2004
  #47
RESIDENT ROTOR HEAD
Damn I only **** once a day...wow...you eat alot?
Old Dec 5, 2004
  #48
Akutenshi's Avatar
The Rizing Sun
great posts guys. im in the same situation as the creator of the thread. been drivin pretty harsh on my 04 a/t sedan. felt kindah bad, n had a fear that i probably REALLY shouldnt be doin that to it. everyones post helped inform me alot. ty
as for the engine being louder... wen my friend pushes down slowly on the accelerator n lets go, while i stand behind the car. i hear this low deep sounding sound. it wasnt like that before. ive got like 6k miles on it, n daily drive it. maybe hit 6000rpm a few times a day. (not good). is there nething wrong? or is it supposed to be like that.
