Anyone get a leak under glove compartment after carwash?
Old Dec 4, 2004
pinkytube's Avatar
pinkytube is an unknown quantity at this point
Weird!
My 2002 Civic EX just started leaking car wash soap after taking it to a car wash. I noticed the color soap under the glove box, coming down slowly onto the passenger side carpet. The car has 80000km's on it, I think whatever it is should be covered by warranty. Does anyone else have this problem?? Do you think it might have something to do with the cold? ( It was -10 yesterday ), and then the hot water coming in maybe caused some damage somewhere? I hope this is fixable! I don't want rust to start forming anywhere near the firewall! i had an 85 accord that literally cracked in half at the firewall due to rust!
Any help would be GRRREAT! Thanks!
Old Dec 4, 2004
Maurizio's Avatar
Maurizio is an unknown quantity at this point
Don't have that problem, but then again, I've never washed my car when it was freezing out. In my opinion, that's just asking for trouble.
The hot water gets into the nooks and crannies that you can't dry off, then freezes (expanding while doing so).
Old Dec 4, 2004
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
do u have anything drilled thru the firewall? like a power wire or anything? a lotta car washes have underbody spray, and something could have leaked inside while going thru
Old Dec 4, 2004
d17a2's Avatar
d17a2 is an unknown quantity at this point
Wadup
Hey these are civics we own! not P.O.S's, hand wash it! ARE YOU CRAZY! I have a 2004 Civic Ex and when I HAND wash mine I never have a leak.... You should hand wash yours less scratches.. I cant believe you!
Old Dec 4, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Civics are POS's...they are almost the lowest class of new car avilable. As soon as I can get rid of mine I will.
You probably have a grommet popped out of the firewall...peel back your carpet under the dash and take a look. You could also have a leak coming in via the floor HVAC vents if you got condensation in there from the A/C or humid/damp weather.
Old Dec 4, 2004
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
Woah man...7 posts and you're already being a jerk....CALM.....
A lot of people don't have the time for a hand wash...so they make a quick run out to the car wash. As for the leak, I'd say yeah, probably firewall issue......although if it's the soap leaking down, it's probably not from an underbody spray...IMO, it's probably coming through the wiper cowl....just outta curiosity, since I don't own a civic, I'm not sure, but you guys have an open-air vent, right? Not sure if they even still bother with them...but if so, was the vent open? Could've leaked down through there....
Old Dec 4, 2004
Got Boost???'s Avatar
it would suck but could it be that you have a hole rusted through?
Old Dec 4, 2004
d17a2's Avatar
Wadup
Guess you didnt realize that I was being sarcastic, anyways post counting your real mature lol
Old Dec 4, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
the sun roof has a drain tube that runs down the inside of the car and out through the side just befor each door and under the dash. the tube could have popped out or the side wall and is now draining in to your car. It should be a clear tube. if you look under your dash you will see it.
Old Dec 4, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
AC has a drain line too. I would check that for clogs.
Old Dec 4, 2004
evilone's Avatar
Wow....punctuation owns your ***....and yeah, last I checked, sarcasm didn't show through text....but I guess your IQ has to reach 30 before that realization hits.
Do the world a favor, go end yourself.
Edit...Just a thought, but you DO know that the putting a title on replies is optional, right? And if you are going to put a title on EVERYTHING, do yourself a favor, expand your vocabulary beyond "Wadup." Who knows, you MIGHT be able to fake intelligence by learning more than 15 words.
Old Dec 4, 2004
civic2uner's Avatar
Old Dec 4, 2004
Blainestang's Avatar
Blainestang has a spectacular aura aboutBlainestang has a spectacular aura aboutBlainestang has a spectacular aura about
My parents' TL had this problem and they said it was a bad windshield seal. We had just gotten the windshield replaced and it began to leak under the glovebox. Might not be it, but sounds similar.
Old Dec 4, 2004
civic2uner's Avatar
Wadup
^^^^^wadup
I cant get over that. 2x in a row. roflmao.
n00b got own3d
Old Dec 4, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
yes i have an 03 and it leaked on the trunk and on the passanger side after it rained and / or washed it i took it to honda they had the car for like 3 days they changed some stuff and after that no problem
Old Dec 4, 2004
Roosbok's Avatar
Roosbok is an unknown quantity at this point
I haven't had this leaking problem, as far as I know, but does your assesment of the Civic extend to all Honda's? The reason I ask, is that I am thinking of getting an Accord. I bought the Civic thinking it was the top small car out there, but I too think it has mediocrity built into it (with some strong points, but I don't have enough miles on it yet to be sure). If the mediocrity of the Civic is systemic, then it would logically follow that the Accord is flawed as well. Should we stay away from Hondas altogether, and go to a larger Japanese manufacturer that shall remain nameless?
Old Dec 5, 2004
Mystic3030's Avatar
The accord is a good car, but the Camry is built better.
Old Dec 5, 2004
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
well...are you using the drive thru wash? if so, thats a mistake in itself. but if your washing it pressure wash style then just make sure that your not squirting it into the cracks of your car. its also not good to wash your car when its -10 degrees outside (where the hell do you live by the way) especially when you apply hot water to it. that might make some objects crack. i know class is prone to that.
i love the noob-syndrome
GotSiR
Jun 23, 2016 04:06 PM
carid
Nov 7, 2015 01:46 AM
cukaracha
30
Jul 26, 2015 12:01 PM
