Car and drivers 1999 First Test of an S2K
Old Nov 25, 2004
vtecpimp's Avatar
vtecpimp is an unknown quantity at this point
August 1999, 122 cu in, 1997cc 240hp@8300rpm 153 lb-ft@7500
0-60.......6.8
Standing Quarter........15.1 sec @96mph
Top speed ( drag limited)..........146mph
Roadholding,300-ft-dia skidpad...........0.90 g
July 2004 (same mag), 132 cu in, 2157cc 240hp@7800 162 lb-ft@6500
0-60.......5.5
Standing Quarter........14.0 sec @100mph
Top Speed.........150mph
Roadholding, 300-ft skidpad..........0.88 g
I realize that there has been a slight bump in power to boost bottom end of these, as well as a reduction in redline, but in 1999 was it that the car wasn't as well put together yet as it was in the last few years or that the guys at Car and Driver just couldn't drive it back then. Also do you think that it's reduction in roadholding ability is attributed to the factory " detuning" ( damn I hate that word) the car this last year to make it a little more userfriendly?
Old Nov 25, 2004
robbclark1's Avatar
Retired suspension supermod.
i think it has gotten a lot better over the years. You have to figure it is the first year of the car and things are always as they seem. Regardless of what the engine puts out I am sure Honda made some fine adjustments to make the wheel HP better as the car evolved. I am disappointed by the reduction in skidpad but that may be due to the less oversteer in the newer one.
Old Nov 25, 2004
nindoo's Avatar
Why is my vagina bleeding?
Maybe the one right before the latest one is the best one.
Old Nov 25, 2004
Pharoh's Avatar
Bobaganoosh!
02 and 03 are the best I think.
Old Nov 25, 2004
mykungfuisthebe's Avatar
mykungfuisthebe is an unknown quantity at this point
i drove a 2000 and it had hella oversteer... almost to much.. from the short wheelbase... it was my cousins... he says its much better since hes worked on the springrates and roll bars
Old Nov 25, 2004
nindoo's Avatar
Old Nov 25, 2004
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
I believe that the tires remained the same on all years, even now (Potenza S03) however the larger diameter wheels probably attributed to the lower cornering g's (more unsprung weight, etc...) Just a guess.
Old Nov 25, 2004
scatman's Avatar
Still in the game...
i thought those things ran 13's??.....hmm, where did i read that
Old Nov 25, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
well the new f22c has more top end and yes you are right the engine has been detuned to make it a little more user friendly that engine was supposed to be making arround 250hp but honda engineers only wanted torque and saved those 10 hp to keep it an economical engine on gas
even though the 9k rpm from the f20c is awesome but it takes skill to get the full potential out of that car with the new one not that much
Old Nov 25, 2004
zachgeyer's Avatar
that sweet
Old Nov 25, 2004
Changu-San's Avatar
Mr. Clean
they run low-mid 14s stock.
Old Nov 25, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
it got a little heavier and the bigger wheels dont help the skidpad but the new stiffer front end and torque are really big improvements. remember that these are just test numbers, they only tell part of the story. and yes the newer ones are faster
Poopies
Apr 20, 2017 11:36 PM
usajags84
15
Aug 19, 2015 03:12 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
