need DIY help (nevermind, please delete)
Old Nov 14, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
wrong forum i know, but i need a fast reply... sorry.
i'm doing the diy rotor replacement, and those damn screws are a big pain in the ***, i'm just about stripping them. i don't have the impact screwdriver. how else could i get those suckers off? how do you drill them out? and how much are impact screwdrivers?
Old Nov 14, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
they are reverse thread. Go in the opposite direction. You are just tightening them heh.
Old Nov 14, 2004
kikoy's Avatar
kikoy has a little shameless behaviour in the past
25 bucks at sears/craftsman... and yiu can try to beat the screws w/ a hammer and yse a screw druver after......an if you strip it you may want to drill it and not put any screws after(no use anyway/my opinion)
Old Nov 14, 2004
Skunk2ner's Avatar
how do i drill out the screw? i'm screwed, so to speak.
Old Nov 14, 2004
joe6680's Avatar
Have you tried my suggestion??? Honestly its not un-common for screws in that area to be reverse threaded. Just try it what do you have to lose? Instead of trying to loosen the screws try tightening them. If they are reverse threaded they will come out.
Old Nov 14, 2004
kikoy's Avatar
just get an air drill(if you have air tools) or get a regular drill w/ at least 7500 rom w/ a carbide bit....and just drill it out....and if you hav the patience and the tools, id recommend oversizing the existing thread of the screws and grab a heli-coil and chase it w/ a tap and put the appropriate size screw w/ a grade of 5/grade 5 screw.....and you are set.....either way you can replace or just leave it alone w/o a screw since you are still torquing the caliper and the wheel down....
Old Nov 14, 2004
Skunk2ner's Avatar
problem solved, please delete this thread
Old Nov 14, 2004
import2nr's Avatar
awd pwnz j00
glad you solved your prob!
:deleted:
rezsst
Sep 26, 2015 07:04 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
