carfax help pls
Old Nov 2, 2004
davidoff1's Avatar
davidoff1 is an unknown quantity at this point
carfax help pls
My fren is interested in buying one of these cars..... can someone pls help? I really appreciate it.
VIN# : WDBLK65G31T084054
and
VIN# : WBSBR93464PK07306
Old Nov 2, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
hmmm
those aren't honda VINS so good luck.
Old Nov 2, 2004
Atticus's Avatar
Atticus is an unknown quantity at this point
btw carfax IS NOT 100% acurate. there was a study done somewhere and the carfax info was totally wrong on a certian percent of the test cars.
Old Nov 3, 2004
AndrewD's Avatar
AndrewD is an unknown quantity at this point
Here you go..
Report Run Date: 11/03/2004
Vehicle Description: WDBLK65G31T084054
TitleCheck: No Record Found
Problem Check: No Record Found
Odometer Check: Record(s) Found
Vehicle Information: Record(s) Found
Full History: Record(s) Found
Vehicle Description | TitleCheck | ProblemCheck | OdometerCheck | Vehicle Information | Full History
VIN: WDBLK65G31T084054
Year: 2001
Make: Mercedes-Benz
Model: CLK Class CLK320C
Style/Body: 2 Door
Engine: 3.2L V6 EFI SOHC
Country of Assembly: Germany
Your Vehicle Checks Out! AutoCheck's database for this 2001 Mercedes-Benz CLK Class CLK320C (WDBLK65G31T084054) show no significant Title events. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Problems Checked Results Found
Abandoned No Abandoned Record Found
Damaged No Damaged Record Found
Fire Damage No Fire Damage Record Found
Grey Market No Grey Market Record Found
Hail Damage No Hail Damage Record Found
Insurance Loss No Insurance Loss Record Found
Junk No Junk Record Found
Rebuilt/Rebuildable No Rebuilt/Rebuildable Record Found
Salvage No Salvage Record Found
Your Vehicle Checks Out! AutoCheck's database for this 2001 Mercedes-Benz CLK Class CLK320C (WDBLK65G31T084054) shows no historical events that indicate a significant automotive problem. These problems can indicate previous car damage, theft, or other significant problem.
NHTSA Crash Test Vehicle No NHTSA Crash Test Record Found
Frame Damage No Frame Damage Record Found
Major Damage Incident No Major Damage Record Found
Manufacturer Buyback/Lemon No Manufacturer Buyback/Lemon Record Found
Odometer Problem No Odometer Problem Record Found
Recycled No Recycled Record Found
Salvage Auction No Salvage Auction Record Found
Water Damage No Water Damage Record Found
Your Vehicle Checks Out! For this 2001 Mercedes-Benz CLK Class CLK320C (WDBLK65G31T084054) no indication of an odometer rollback or tampering was found. We determine odometer rollbacks by searching for records that indicate odometer reading that are less than a previously reported value. Other odometer events can report events of tampering, or possible odometer breakage.
Report Date: 11/03/2004
Date Reported Odometer Reading
05/14/2001 24
10/05/2001 3,181
09/10/2004 11,689
09/15/2004 11,689
Information Found! AutoCheck found additional information on this vehicle. These records will provide you with more past history for this 2001 Mercedes-Benz CLK Class CLK320C (WDBLK65G31T084054).
Accident Data No Accident Data Record Found
Corrected Title No Corrected Title Record Found
Driver Education No Driver Education Record Found
Duplicate Title No Duplicate Title Record Found
Emission/Safety Inspection No Emission/Safety Inspection Record Found
Fire Damage Incident No Fire Damage Incident Record Found
Lease Lease Record(s) Found
Lien No Lien Record Found
Livery Use No Livery Use Record Found
Government Use No Government Use Record Found
Police Use No Police Use Record Found
Rental/Fleet Rental/Fleet Record(s) Found
Repossessed No Repossessed Record Found
Taxi Use No Taxi Use Record Found
Theft No Theft Record Found
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
VIN: WDBLK65G31T084054 2001 Mercedes-Benz CLK Class CLK320C
Event Date Event Location Odometer Reading Data Source Event Detail
03/31/2001 NJ Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
05/14/2001 NJ 24 Motor Vehicle Dept. TITLE (Leased Vehicle)
10/05/2001 NJ 3,181 Independent Source INDEPENDENT INSPECTION/THEFT DETERRENT EQUIPPED
07/15/2002 NJ Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
05/31/2003 NJ Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
05/31/2004 NJ Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
09/10/2004 11,689 Auto Auction REPORTED AT AUTO AUCTION
09/15/2004 MO 11,689 Auto Auction AUCTION ANNOUNCED AS FLEET/LEASE
Second VIN
Vehicle Description: WBSBR93464PK07306
Vehicle Information: No Record Found
VIN: WBSBR93464PK07306
Year: 2004
Make: BMW
Model: 3-Series M3
Style/Body: 2 Door Convertible
Engine: 3.2L I-6 MPI
Your Vehicle Checks Out! AutoCheck's database for this 2004 BMW 3-Series M3 (WBSBR93464PK07306) show no significant Title events. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Your Vehicle Checks Out! AutoCheck's database for this 2004 BMW 3-Series M3 (WBSBR93464PK07306) shows no historical events that indicate a significant automotive problem. These problems can indicate previous car damage, theft, or other significant problem.
Your Vehicle Checks Out! For this 2004 BMW 3-Series M3 (WBSBR93464PK07306) no indication of an odometer rollback or tampering was found. We determine odometer rollbacks by searching for records that indicate odometer reading that are less than a previously reported value. Other odometer events can report events of tampering, or possible odometer breakage.
06/08/2004 4
10/07/2004 1,745
Your Vehicle Checks Out! AutoCheck shows a clean record for this 2004 BMW 3-Series M3 (WBSBR93464PK07306). For some cars, past vehicle information may give indication of excessive wear and tear, such as police cars or taxi use.
Lease No Lease Record Found
Rental/Fleet No Rental/Fleet Record Found
VIN: WBSBR93464PK07306 2004 BMW 3-Series M3
04/30/2004 NJ Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
06/08/2004 SOMERS POINT, NJ 4 Motor Vehicle Dept. TITLE
10/07/2004 PA 1,745 Auto Auction REPORTED AT AUTO AUCTION AS DEALER VEHICLE
Old Nov 3, 2004
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
could you do a VIn check for me possibly???
Old Nov 3, 2004
davidoff1's Avatar
Originally Posted by lkm
hmmm
yeah forgot to mention it's BMW and Mercedez.....
Old Nov 3, 2004
davidoff1's Avatar
Thanks a lot Andrew...... really appreciate it.......
Old Nov 3, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Yeah you still gotta be careful cause if a car is in an accident or flood or anything that there is no police report or insurance claim for will not show up. So if the car was flooded lets say and the owner took care of it themself then carfax won't show it on the report.
Old Nov 3, 2004
Atticus's Avatar
^ word. ^
Old Nov 3, 2004
davidoff1's Avatar
true... but that's the risk he has to take
