idling problems
Old Oct 13, 2004
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
idling problems
when my car is just sitting there idling(spelling) the rpm will drop below 1 and it will start to stutter like it's going to stall, does anyone know what could be causing this? one of my friends said it might be bad fuel....
Old Oct 13, 2004
read the idle adjust sticky thread in vehicle problems forum.
Old Oct 13, 2004
exclusive_vtec's Avatar
mmmmm whats ur current millege? ur fuel pump might be goin bad... try cleaning, maybe reset the ecu see if that helps
Old Oct 13, 2004
BERGER's Avatar
i have just over 33000 km
Old Oct 13, 2004
take it to ur local dealer... check it out.. shouldnt cost u anything just for dygonsis
Old Oct 13, 2004
03civicdx's Avatar
03civicdx is an unknown quantity at this point
well first of all theres alot of stuff that could be wrong, first how long has this been happeneing, is it stick or boring.. i mean auto, you could have a bad coil, seeing as we have a "DIS" system meaning distributorless as well as a "COP" Coil over plug system you car just may need a goofd tune up, Also we have what you call a map sensor on the car, Also possible cause of erratic idle, a Vacuum Leak will make an irratic idle, to be honest thats a very large question that would be very hard to answer on the computer, you may have a clogged fuel filter or clogged injectors any little thing could be going wrong so you have to start testing things
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
