ok....need more help...
Old Dec 2, 2001
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
ok...thx for everyone that answered my 17" and no drop question....now i got a new one
im not goin have alot of cash. so should i get springs for now then buy coilovers when i get more cash or get springs and wait till they make full suspesion upgrades for our cars?
Old Dec 2, 2001
0100010's Avatar
0100010 is an unknown quantity at this point
Well, if you buy just springs now, then you will probably want to buy new struts eventually. So 200 now for springs 500-600 later for new struts. May have to get camber kits, depending on drop(about 220).
Or, you could go with coliovers now, for around 300-400, and then also get new struts later(550), but you will probably decide to go pretty low, which means you should get camber ktis, so add another 220.
Or, you could go with a full coilover system now for about 1000-1200, this would replace your stock springs and struts, and I would recommend camber kits with this as well, add another 220.
This is before new rims/tires, before strut bars, and before sway bars, if you want them.
When your suspension is all said and done, you will have spent a significant amount, for example, when my car is done, I will have spent about 870 dollars on each corner. A large part of that is the cost of my wheels, but even with normally priced wheel, that usually run about 140 each, then your looking at a cost of about 680 a corner.
mrohitredd
Apr 15, 2015 08:13 PM
FlippedOut
Feb 11, 2003 06:27 PM
Jotosuds
Detailing
Nov 2, 2002 06:31 PM
