Interior fabric makes TeLLy ambitious
Old Sep 9, 2004
  #31
TeLLy's Avatar
Yes, it's an Acura EL
Hey Wally it's real easy - the DIY is perfect, and actually you're quite lucky that you have a sedan, so you're not popping clips to remove the handles - just screws. If you read up on it the whole process takes about an afternoon. I started at around 11 that day and finished around 5 or 6, with weed breaks, entertaining nox_slang, azn_outlaw, and mikeweb, and watching several video awards shows on the tube.
If you haven't already this is the perfect time to paint the 1.7 door trim pieces as they'll be easy to put back on while the panels are off the car. Another plus is you'll be able to reuse the round clips that hold the door trim pieces on - something I couldn't do because the first time I painted the door trim I simply pulled them off the doors, breaking clips as I went.
Old Sep 9, 2004
  #32
mndthegap1's Avatar
that looks really good ... nice job !
Old Sep 9, 2004
  #33
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
Oh, so with this method, you can actually PROPERLY remove the faux wood trim pieces? Or is it because the cloth is removed and doesn't hinder you from just painting away?
As I recall, they're held on by rivets. But they don't seem easy to pop back in place by hand. But this really does look like a neat DIY
Old Sep 10, 2004
  #34
TeLLy's Avatar
What I'm saying is that since the door panels are OFF the car, you can properly RE-ATTACH the trim pieces, without resorting to automotive goop like I originally did. They're not held on by rivets, they're held on by those toothed rings (I forget what they're called on Mcmaster.com), so instead of ripping them out from the door like I did, you can actually pull off and reuse those ring thingies.
Old Sep 20, 2004
  #35
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Damn Telly - looks freaking sweet. Love the red trim pieces too.
Old Sep 20, 2004
  #36
TeLLy's Avatar
Thanks Martin. Compliments coming from a DIY guru like you mean a whole friggin lot, believe me.
Old Oct 11, 2004
  #37
Ricochet's Avatar
Ricochet is an unknown quantity at this point
just woundering, where is this write up 2 do all this vinyling ?
Old Oct 11, 2004
  #38
Karumba's Avatar
Boredom causes changes ;)
Originally Posted by Janlop
wow .. took me a while to find it - okay I'm tired, but here's the link/threads I believe he used AzNBonD: http://www.7thgencivic.com/forums/sh...iy+door+panels and originally http://www.7thgencivic.com/forums/sh...ad.php?t=46272
Believe you search for these ..
Old Oct 12, 2004
  #39
TeLLy's Avatar
I never said anything about vinyl, ha ha.
Old Oct 12, 2004
  #40
Ricochet's Avatar
well could u please tell me what 2 use then ?
i wanna do it black and blue.
thanks.
Old Oct 12, 2004
  #41
TeLLy's Avatar
Use whatever you want. Vinyl works well - as does any material that's not too porous. I had trouble with mine because it let a little bit of the adhesive soak through - I might redo a door.
Old Oct 12, 2004
  #42
el-type-r's Avatar
el-type-r is an unknown quantity at this point
i wish my ride wuz nice.........my car iz ugly
Old Oct 12, 2004
  #43
Ricochet's Avatar
any tips or tricks any1 can give me please?
cause those DIYs don't help too much.
Old Oct 13, 2004
  #44
TeLLy's Avatar
Read them carefully, the DIY is all I needed. And I'm BAD with upholstery. Once you get those bad boys off you'll see what I mean.
Old Oct 13, 2004
  #45
Ricochet's Avatar
well the furst DIY looks simple. the second one i dunt even underestand...lol.
any other DIYs around guyz?
thanks fo all help.
Old Oct 13, 2004
  #46
TeLLy's Avatar
Use the 1st one, the 2nd one is really more of a reference and is not very relevant to the 1.6's.
Old Oct 13, 2004
  #47
Ricochet's Avatar
iight thanks.
not much steps though eh. its just like cut to shape and glue on.
Old Oct 13, 2004
  #48
TeLLy's Avatar
That's pretty much all it is. When you pull off the original fabric, you'll see at the same time how the new fabric will go on.
Old Oct 21, 2004
  #49
Ricochet's Avatar
i took mah door panels off and everthing and i looked at it. but i'm kinda lost..lloll...i'm not too god at dis stuff.
Old Oct 22, 2004
  #50
TeLLy's Avatar
You just peel the cloth off and scrape off whatever adhesive remains on the door. It's in the DIY man.
Old Oct 23, 2004
  #51
Ricochet's Avatar
what kind of glue did u use?
cuz all i could find wuz 3M adhesive 76 and 77.
Old Oct 25, 2004
  #52
TeLLy's Avatar
The same stuff from the DIY.
Old Oct 25, 2004
  #53
Ricochet's Avatar
i can't find the 90 anywhere
i found 3M 77 and 76 but not 90.
Old Oct 25, 2004
  #54
TeLLy's Avatar
I just checked my spray-can stash - I used 77.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
doncarbone
Jun 8, 2015 03:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
CosmicPulse
Nov 9, 2001 05:06 AM
